ttn said:
Your pet phrase "nonlocal observational context" seems to be merely a euphemism for: there's non-locality going on, the situation is non-local, what's happening violates Bell Locality. But that shows the inanity of your overall statement: Bell's locality condition doesn't apply in situations where Bell Locality is violated.
Well duh. =b
Duh indeed. :-)
Using an lhv formulation to describe a global observational context
is sort of like using a 1/2 inch wrench to turn a 1 inch nut. Is
it a big deal to discover that you can't do that?
Bell locality is 'violated' due to an incorrect interpretation
of the physical meaning of the qm method for calculating
joint probabilities. The probability of individual detection at
either end is always .5, and it's actually the joint probability
that you're calculating after detection at one end or the
other and then projection.
Sherlock said:
Events at A and B, in the global context, are related, but not
to each other via signalling across spacelike separations. They're
related to each other due to a relationship imparted at emission, which
can be regarded as a hidden global constant, which is captured in
the experiments by time-correlating the results.
ttn said:
No, this is precisely what Bell's Theorem shows is impossible. You can't attribute
hidden variables to the pairs at emission such that the correlations are explained.
If you reread what I wrote, you'll see that I'm not attributing hidden
variables to the pairs at emission. I'm attributing a hidden relationship
(call it the entanglement at the submicroscopic level) that doesn't vary from
pair to pair. A hidden constant.
ttn said:
That's no doubt what Einstein thought -- that physicists should look for a local hidden variable theory of this kind was precisely the conclusion of the EPR paper. But we now know it isn't possible. Bell proved that *no* Bell Local hidden variable theory can reproduce the QM predictions. So a common cause explanation like you are arguing for above is ruled out, period.
A common cause hidden variable accounting is ruled out -- but not a
common cause hidden constant. The variable that actually determines
the joint results isn't hidden.
ttn said:
Listen to what you're saying: a global instrumental variable (which I gather means "theta", the difference angle between the settings on the two sides) determines the results A and B. OK, so in particular, the result A is due (at least in part) to the setting over by B, and vice versa.
That's nonlocality -- it violates Bell Locality. Throwing a bunch of confusing and ill-defined terms (like "observational context") at the problem isn't going to make that fact go away.
What you're calling a fact isn't, in fact, a fact.
The results at A aren't (even in part) due to the setting at B, and vice versa.
If you vary the setting at A you'll see no corresponding change in the rate of detection at B, and vice versa. You can do anything you want at one
end (turn it upside down, pour beer on it, play rap music to it, etc.) and it
will in no way affect the rate of detection at the other end.
But, you *will* have altered the *joint* results (perhaps irreparably). :-)
A and B are correlated via timing (which is designed to ensure that paired results are
associated with disturbances produced by the same interaction or emission event).
Then (A,B) is correlated to Theta.
Sherlock said:
Bell treated the hidden global parameter, due to emission, as a
determining variable in the global context, which doesn't work.
ttn said:
Right, it doesn't work -- i.e., if you assume there is no Bell Locality, your
theory doesn't work, it doesn't match the correct QM predictions. That's
Bell's Theorem. You talk as if the very content of the theorem is somehow
a proof that the theorem is invalid!
The mathematical theorem itself is valid. Interpretations of it
which say that it shows that there must be superluminal signalling,
or that it shows that there can't be real physical disturbances with
real physical characteristics moving between emitter and detector,
or that it shows that local hidden variable theories are impossible
are invalid.
The experimental violation of Bell inequalities does have an
important use however. It can be used as an indicator of the
presence of entanglement.
Sherlock said:
Treating the hidden global parameter as a constant in the
global observational context does work.
ttn said:
Of course it works. Orthodox QM (with its nonlocal wave function collapses) also works. Bohmian Mechanics (with its nonlocal dynamics) also works. Lots of theories with different sorts of nonlocality in them "work."
Bell proved that *only* such (nonlocal) theories "work." Are you disagreeing with that claim? It's hard to tell since you say at once that his argument is inapplicable, and that your alternative is nonlocal.
Bell's argument is that lhv descriptions of global contexts are
incompatible with qm descriptions and experimental results
of those contexts. Ok. So what does that mean? It means he's using
the wrong 'wrench'. It doesn't mean that lhv's aren't relevant in *any*
context -- of course they're relevant in some contexts.. It doesn't mean
that there's nothing real happening between emitters and
polarizers -- of course there is. It doesn't mean that there are no local
hidden variables -- of course there are, they just aren't relevant to the
results in the global context. It doesn't mean that we need to start thinking
about what sort of superluminal signals might be propagating between
A and B, because it doesn't rule out an emission-produced global
hidden *constant*.
ttn said:
In other words, there are certain experiments which can be explained by a local hidden variable theory, and some others that can't. That's true. But this only means that, in general, the local hidden variable theories cannot be right.
No, it means that some experimental results are determined by local
hidden variables and some aren't. A good general theory makes the
contextual requirements clear -- so that you don't use the wrong tool
for a particular job.
ttn said:
Oh I see. So the people who are bothered that the nonlocal parts of nature contradict
relativity should just look at something else... then the contradiction goes away. (Pass the beer!)
System-dependent behavior doesn't contradict relativity. Global observational
contexts involving correlations of global variables don't contradict relativity.
People who are "bothered that the nonlocal parts of nature contradict
relativity" have incorrectly interpreted the physical meaning of experimental
violations of Bell inequalities. Perhaps these people, along with the guy
who hypothesizes a new force of nature to account for his picking the wrong
wrench and the people who are bothered by the color scheme of the new
phone books should indeed look at something else for a while, or at least
cut down on the beer. :-)
