Traveling Fast and Infinite Mass
  • Context: Graduate
  • Thread starter Thread starter Cladson
    Infinite Mass
The discussion revolves around the concept of using black holes for transportation, particularly the implications of traveling near the speed of light and the associated effects of time dilation. Participants explore theoretical ideas related to black holes, wormholes, and the challenges of space travel.
  • One participant questions whether using black holes for transportation would require traveling faster than the speed of light, which they believe leads to infinite mass.
  • Another participant introduces the idea of a subway train traveling near the speed of light, suggesting that it would experience distortion and time dilation, leading to a longer duration of time experienced outside the train compared to inside.
  • A participant references Einstein's equations regarding rotating black holes and the theoretical possibility of traversable wormholes, while noting that many physicists consider this impossible.
  • Another participant agrees that time dilation would mean that while falling into a black hole appears to take a long time from an outside perspective, it would happen quickly for the person falling in.
  • One participant challenges the assertion that traversing black holes is widely considered impossible, citing physicists like Kip Thorne and Roy Kerr who have explored such ideas.
Participants express differing views on the feasibility of using black holes for transportation and the implications of time dilation. There is no consensus on the possibility of traversable wormholes or the practicality of such concepts.
Participants discuss complex theoretical concepts without resolving the underlying assumptions or limitations of their arguments, particularly regarding the nature of black holes and the effects of relativistic speeds.
Cladson
Now somewhat near the end of Hyperspace, It spoke of black holes and how light can't escape. Doesn't that mean that if we wanted to use black holes for transportation then we would have to go faster than the speed of light?
Which I've read many times is impossible because you would obtain infinite mass. I had a strange thought to, In Hyperspace it said to imagine a subway train that would go near the speed of light, it would get squished up and distorted and then expand to fill up the station when stopped. Doesn't Time Slow down when you go that fast? So say you take a 2 minute train ride, wouldn't that be a lot longer off of the train?
The solution of Einstein's equations for the case of a rotating black hole suggests that it might contain inside it a sort of wormhole to "somewhere else", but the solution doesn't say where. To use it (and this is generally held to be impossible by most physicsts) you first fall into the black hole, somehow avoiding the tidal forces that will tear you apart, then enter the mouth of the tunnel, traverse it, and come out wherever it goes. Whether that is inside another black hole or not is not said. Generally nobody except maybe Kaku thinks this would ever be possible even in principle.
Well before we Find a way to traverse black holes we should find a way to build colonies in space so we can take an entire city of people because do to the time dialtion everyone you know that hasn't gone through the black hole would die because and hour of black hole travel would be like forever on Earth am i correct?
Yes, seen from far away, the time to fall into a black hole would take literally forever. But to the people falling, it would happen fast. This is according to the usual accepted understanding of black holes.
Really? I happen to remember several physicists working on such ideas, including traversable wormholes by Kip Thorne and spinning black hole rings by Roy Kerr. Black Holes & Time Warps by Kip Thorne even goes into detail on how something like this could be accomplished.
  • · Replies 45 ·
  • · Replies 130 ·
17K
  • · Replies 20 ·
