.Is the Urban Myth about China Jumping Off a Ladder Real?
  • Context: High School
  • Thread starter Thread starter Peter Pan
    China
The discussion addresses the urban myth regarding the potential impact of 2 billion people in China simultaneously jumping off ladders on Earth's orbit and rotation. Key considerations include the mass of the Earth, the conservation of momentum, and the total energy generated by such an event, estimated at 1 trillion joules. This energy is equivalent to a magnitude 5.5 earthquake, which would be negligible in terms of global impact, similar to the effects of nuclear tests. The conclusion is that such an event would not significantly alter Earth's trajectory or rotational dynamics.
  • Understanding of conservation of momentum
  • Basic knowledge of gravitational potential energy
  • Familiarity with earthquake magnitude scales
  • Concept of energy equivalence in physical phenomena
  • Research the principles of conservation of momentum in physics
  • Explore gravitational potential energy calculations
  • Study the Richter scale and its implications for earthquake measurement
  • Investigate the effects of large-scale human activities on geological stability
Students of physics, geophysicists, and anyone interested in understanding the relationship between human actions and geological phenomena.
Peter Pan
Help me disspell this urban myth(sorry to waste all of your time)
If everyone in china jumped off a ladder at the same time, would it be enough to knock the Earth out of orbit or mess up how it(the earth) rotates on its axis?
a few things to concider
1) how far everyone is spaced apart
2) how tall the latter is
3) average weight of the 2 billion people in china
sorry, i didnt see that this question was just posted
A few other things to consider
1) The mass of the earth
2) The momentum of the Earth in its orbit
3) The conservation of momentum
Conservation of momentum implies that if one chinaman climbs a ladder and then jumps back down, then the net movement of the CG of the system is 0. Not close to zero -- but actually zero. So the sum of any number of people jumping off of ladders is not going to cause the Earth to go off kilter either. Unless something actually reaches escape velocity, it can't have a long-term effect on the Earth's path.
Now. let's say that there are N chinese, with average weight m, jumping from height h. Then the total energy is about
Nmgh
Let's use some conservative numbers here:
Let's say that there are 10 billion chinamen
Let's say that they weigh 100 kg each
Let's approximage the acceleration of gravity with 10m/s/s
Then we have
10,000,000,000*100*10=10,000,000,000,000
1*1012 joules of energy.
The earthquake chart at http://www.geop.itu.edu.tr/~onur/seis/energy.html
gives that as equivalent to a magnitude 5.5 earthquake, or about a fifth of a Nagasaki bomb.
A magnitude 5.5 earthquake in San Francisco probably wouldn't even be noticed outside California without special detection equipment.
I would guess that you would see a larger earthquake every week or two.
It certainly pales in comparison to the Castle/Bravo nuclear test which was thousands of times larger.
Based on the results from nuclear testing and earthquakes, some of the people in nearby countries might notice.
Regarding spacing and synchronization -- the Nuclear Bombs typically have all of the energy within just a few cubic meteres, and effectively instananeously.
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 50 ·
