How do you calculate ampere turns for a toroid with an air gap?
  • Thread starter Thread starter hiiragizawa
    Magnetostatics
The discussion revolves around calculating ampere turns for a toroidal inductor that includes an air gap. The problem involves parameters such as the cross-sectional area, mean radius, magnetic flux density, and relative permeability, which are relevant in the context of electromagnetism.
  • The original poster attempts to understand the implications of having an air gap in a toroidal coil and expresses confusion regarding the relevant formulas and concepts. Some participants discuss the relationships between electric current and magnetic fields, referencing Ampere's Law and the effects of the air gap on magnetic properties.
Participants are actively engaging with the problem, offering insights into relevant equations and concepts. There is a mix of clarifying questions and foundational explanations being shared, indicating a collaborative effort to deepen understanding of the topic.
The original poster notes a lack of coverage of air gaps in their syllabus, which may affect their ability to fully grasp the problem. There is also a reference to a specific educational resource that could provide additional context.
hiiragizawa
I'm very sorry if this questions seems easy to you guys but it's been giving me a hard time.
An iron ring has a uniform cross-sectional area of 150mm^2 and a mean radius of 200mm. The ring is continuous except for an air gap of 1mm wide.
Calculate the ampere turns at the air gap when B= 0.5T, and relative permeability is 250.
I have tried searching for another example of a 'toroid-but-with-an-air-gap' question in several books including Fawwaz T. Ulaby's Electromagnetic for Engineers but to no avail. The only formula that i could think of is H = (-N*I)/(2*pi*r) and that would mean leaving out the area of the cross section of the ring.
What does it mean when the toroid has an air gap like that? So far, there isn't anything like that covered in my syllabus. I have only covered magnetic field for an infinitely long wire and the toroidal coil.
Any help is greatly appreciated.
Thanks
Are you familiar the relationship between electric current and magnetic field (Ampere's Law)?
N i = H lc where c designates the magnetic core.
Also B = [itex]\mu[/itex] H
Now with a gap in a magnetic conductor
N i = Hc lc + Hg g, where g is the gap (distance between faces).
The [itex]\phi[/itex] = B * A, where [itex]\phi[/itex] is the magnetic flux.
Hello there. Thanks for replying.
The only relationship i know is as below :
[tex]\int[/tex] B.dl = [tex]\mu[/tex]I
N i = H lc where c designates the magnetic core. Does small i denote the current?
Do we have to use the boundary condition for this type of case? Where Bgap=Bint?
Yes, i is the current.
[itex]\Large\int_S J\cdot da = \oint H \cdot dl[/itex]
I believe this will be of use in understanding the problem - http://services.eng.uts.edu.au/~joe/subjects/eet/eet_ch4.pdf pdf file.
16K
  • · Replies 17 ·
12K
44K
