Earth's rotation and gravitation
  • Context: Undergrad
  • Thread starter Thread starter quasi426
    Gravitation Rotation
The discussion clarifies the distinction between centripetal force and gravitational force, emphasizing that they act in different directions. The centripetal force is defined as any force that pulls towards the center of a rotating system, while gravitational force acts downward. At the equator, the normal force is less due to the Earth's rotation, which introduces a net centripetal force. If the Earth's rotation were to increase significantly, the normal force could potentially reach zero, causing objects to be thrown off.
  • Understanding of Newton's laws of motion
  • Familiarity with centripetal and centrifugal forces
  • Knowledge of gravitational acceleration and its effects
  • Basic concepts of rotational dynamics
  • Study the relationship between centripetal acceleration and gravitational force
  • Explore the effects of Earth's rotation on gravitational force at different latitudes
  • Learn about non-inertial reference frames and their implications in physics
  • Investigate the mathematical derivation of centripetal force equations
Students of physics, educators teaching mechanics, and anyone interested in understanding the effects of Earth's rotation on gravitational forces.
quasi426
I don't understand why the physics book defines the centripetal force and gravitational force acting in different directions.
N - m*(acceleration of gravity) = -m*r*w^2
N = m*(acceleration of gravity) - m*r*w^2
Why don't the acceleration of gravity and centripetal acceleration add up? I would think that the normal force would be greater near the equator since there is both gravitational and centripetal forces in the same direction. But the book says the opposite. Thanks for the help.
Centripetal force is not a kind of force, it is just the name given to any force that pulls towards the center of some rotating system. (Centripetal just indicates the direction of the force, not the source of the force. It's similar to saying that a force acts horizontally or vertically. Centripetal means "towards the center".)
In the case of an object at the equator, the net centripetal force is just the net force acting towards the center. If the Earth didn't rotate, then there would be zero acceleration and N = mg. But the Earth does rotate, so there must be a net force acting centripetally on the object. Thus the normal force is less. If the Earth starting spinning faster and faster, at some point the object would be thrown off--the normal force would go to zero.
Looked at from the noninertial frame of the rotating Earth you can say that there is a centrifugal acceleration on the object that acts to pull the object away from the center. (Centrifugal means "away from the center".) So you could say that the acceleration due to gravity and the centrifugal acceleration add up, but they act in opposite directions.
  • · Replies 47 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 21 ·
