Determine the velocity of an electron orbiting an atom ?
  • Context: Undergrad
  • Thread starter Thread starter Victor Frankenstein
    Atom Electron Velocity
The discussion centers on the impossibility of determining the precise velocity of an electron orbiting an atom due to the Heisenberg uncertainty principle. While it is feasible to calculate eigenvalues of momentum for an electron, this does not translate into classical mechanics, as knowing velocity precisely compromises the accuracy of position. Electrons occupy shells with varying energy levels, and their arrangement is influenced by quantum principles rather than classical laws like Kepler's. A semi-classical approach can be used to estimate velocity through the expectation value of the momentum operator divided by mass.
  • Understanding of the Heisenberg uncertainty principle
  • Familiarity with quantum mechanics and electron shell models
  • Knowledge of momentum operators in quantum physics
  • Basic concepts of semi-classical physics
  • Study the Heisenberg uncertainty principle in detail
  • Explore quantum mechanics principles related to electron shells
  • Learn about momentum operators and their applications in quantum physics
  • Investigate semi-classical approaches to quantum mechanics
Students of physics, quantum mechanics researchers, and anyone interested in the behavior of electrons in atomic structures.
Victor Frankenstein
Is it possible to determine the velocity of an electron orbiting an atom ?
Would the velocity be greater for an atom with more mass ?
It is possible to determine some eigenvalue of momentum for an electron in an atom, but you can't take that and do celestial mechanics with it, because the sharpness in knowing the velocity comes at the cost of vagueness in knowing the position. You can't have a classical orbit without knowing both, and the uncertainty principle says you can't know both accurately at the same time.
Because of uncertainty and its pal the exclusion principle, electrons in atoms arrange themselves in shells, the number of shells increasing through the rows of the periodic table. The outer shells are at a higher energy level than the inner ones, but again there are no Kepler's laws to resort to in quantum land.
Though it´s not appropriate to say ¨the velocity¨ of the electrons in an atom, there´s still semi-classical analog: probability flow density. Also, you can mimic the conception of velocity as p/m, where p is the momentum operator, take the expectation value of p/m, you can get a semi-classical velocity.
