Dalton's Law of Partial Pressures
  • Thread starter Thread starter Qyamat
    Law Partial
Dalton's Law of Partial Pressures states that the total pressure exerted by a mixture of gases is equal to the sum of the partial pressures of each gas. In a scenario with three gases at partial pressures of 400 torr, 500 torr, and 100 torr in a 10 dm³ cylinder, the total pressure upon mixing will be 1000 torr. The Ideal Gas Law confirms that an increase in pressure within a fixed volume leads to an increase in temperature, as the kinetic energy of gas molecules rises. Thus, while the total pressure increases, the individual partial pressures remain unchanged.
  • Understanding of Dalton's Law of Partial Pressures
  • Familiarity with the Ideal Gas Law
  • Basic knowledge of gas behavior in fixed volumes
  • Concept of partial pressures in gas mixtures
  • Study the Ideal Gas Law and its applications in thermodynamics
  • Explore real-world applications of Dalton's Law in chemical engineering
  • Investigate the relationship between temperature, pressure, and volume in gases
  • Learn about gas mixtures and their behavior under varying conditions
Chemistry students, chemical engineers, and anyone interested in the principles of gas behavior and thermodynamics.
Qyamat
Hello ,
If someone could help me out with this problem with I got myself into i will be very thankfull.Dalton says that If there r three gases in a cylinder of 10 dm^3
each containing a gas at the same temperature.Let there partial pressure be 400 torr,500torr,100 torr. Then when alll these three gases r transferred to another cylinder with the same 10 dm^3 volume then The pressure will be the sum of the three ie.1000torr. But will not the temperature increase if pressure increases so considerably. Please do tell me if i am not considring anything worth in this system.
Yes, the temperature will increase when the pressure increases. This is due to the fact that the volume of the cylinder is fixed, meaning that when the pressure increases, the number of molecules in the cylinder has to increase as well. Since the molecules are moving faster at higher temperatures, this causes the temperature of the gas to increase.
Hello,
You are correct in thinking that the temperature will increase if the pressure increases in this system. This is known as the Ideal Gas Law, which states that pressure and temperature are directly proportional when volume and amount of gas are constant. However, Dalton's Law of Partial Pressures is concerned with the total pressure exerted by a mixture of gases, not the individual pressures of each gas. In this case, the total pressure of the mixture will increase to 1000 torr, but the individual pressures of each gas will remain the same. This is because the gases are mixed together and their individual pressures are still contributing to the total pressure of the system. I hope this explanation helps to clarify any confusion.
  • · Replies 67 ·
  • · Replies 23 ·
  • · Replies 27 ·
