Why Does Radio Reception Improve When I Hold an Antenna?
  • Thread starter Thread starter Shawnzyoo
    Radio Transmission
The discussion revolves around the phenomenon of improved radio and TV reception when a person holds an antenna. Participants explore the underlying reasons for this effect, considering various physical principles and the role of the human body in reception quality.
  • Some participants suggest that the human body acts as a better receiver, potentially enhancing the antenna's performance.
  • One participant proposes that the bioelectric output of the body alters the capacitance of the antenna, similar to how proximity alarm systems function.
  • Another participant refines this idea, stating that the effect is not due to bioelectric output but rather to changes in capacitance and inductance, noting that a large object, like a bag of seawater, would have a similar effect.
  • There is a discussion about whether the water content in the human body contributes to its effectiveness as an antenna, with some asserting that it does not, while others clarify that the body may still assist in receiving signals under certain conditions.
  • Participants mention that modifications to the antenna, such as adding tinfoil or a coathanger, could work for similar reasons related to capacitance and effective antenna size.
Participants express differing views on the specific mechanisms at play, particularly regarding the role of the human body and the nature of capacitance. No consensus is reached on the exact reasons for the improved reception.
Some claims about the effects of body capacitance and the comparison to other materials remain unresolved, with participants discussing various assumptions and conditions without reaching definitive conclusions.
Shawnzyoo
can anyone explain to me why radio reception/tv reception ect.. come in more clearly when i hold the antenna?
i am assuming my body is acting as a better receiver
but can someone actually explain why?
thank you
shawn small
I noticed that to when I lived in Bosnia and had to move antennas for the TV so that picture is better. As soon as I would touch the antenna picture would get much better.
Although I don't really know anything about the specifics, I believe that your bioelectric output alters the capacitance of the aerial. Proximity alarm systems such as for cars operate on that principle. If you notice, you can be close to the aerial without actually touching it and still have an effect.
This is close, but it't not the bioelectric output- its just the capacitance
and inductance. A bag of seawater the size and shape of a person
would have the same effect on the TV reception.
Basically, you are either 1) enlarging the size of the antenna by
grabbing it or 2) you are improving the coupling between the receiver
and the antenna's connection. This second effect would be called
impedance matching where the first effect would be called "increasing
the effective aperture of the antenna".
Thanks for that clarification. I never knew what caused body capacitance, so just assumed that it had to do with cellular electrical activity. I suppose then that sticking a piece of tinfoil or a coathanger on it works for the same reason rather than just from changing the shape of the antenna?
Yes.
If you define a pair of electrical terminals, then the configuration of the whole
universe affects the capacitance measured between them. Of course the
more distant objects will have a very small effect.
Capacitance is measured in Farads where [tex]C = Q/V[/tex].
What this says is that if I charge my terminals up to one volt, the
capacitance is a measure of how much charge it took to do it.
A large capacitor can take a large amount of charge before the
terminals get up to one volt. Originally when voltage was thought
to be a form of pressure, capacitance was thought to be like
the "size" or capacity of a storage tank.
A fat, wide tank will take a lot of water before the pressure is high.
This is like a large capacitor.
A tall narrow tank will build pressure quickly with only a little water.
This is like a small capacitor.
so is it the water in the human body that makes it such a good antenna?
No. Salt water or water is not a good antenna material.
It's just that the body may help receive a signal from a small antenna
under the right conditions. Usually the body interferes with the
action of a well-designed antenna.
I only refer to water above to help explain capacitance.
Thanks. That clears up a lot of misconceptions that I had.
thanks for the clarification
is it something specific about the human body that aides the antenna specifically?
  • · Replies 37 ·
  • · Replies 44 ·
9K
