Pulse Tuning - Senior Design Project Advice
The discussion centers on pulse tuning as a senior design project in automotive engineering. The original plan to design a new cylinder head without poppet valves was deemed impractical due to time constraints, leading to the proposal of a continuously variable intake manifold. The participant calculated that at 1000 RPM, the pulse would need to travel approximately 50 meters before the valve opens, which is unfeasible. The focus shifted to utilizing modes of vibration to reduce the necessary design length, with an inquiry into the measurable effects of pulse tuning at low RPM versus high RPM efficiency gains.
  • Understanding of pulse tuning principles in automotive engineering
  • Knowledge of intake manifold design and functionality
  • Familiarity with engine RPM dynamics and their impact on performance
  • Basic principles of oscillation and wave behavior in fluid dynamics
  • Research the design and functionality of continuously variable intake manifolds
  • Explore the effects of pulse tuning on engine efficiency at varying RPMs
  • Investigate the principles of oscillation and their application in automotive systems
  • Study existing automotive applications of multi-stage intake manifolds
Automotive engineering students, design engineers, and professionals interested in advanced intake manifold technologies and performance optimization strategies.
minger
Hi, I am coming into my senior design project and I have a question. Originally, my group was going to design a new cylinder head design without using poppet valves. Being that we only have 15 weeks, we figure we don't have nearly enough time. Wanting to keep an automotive related project, I suggested pulse tuning. I noted that many car companies have a 2-stage and a couple even a 3 stage intake manifold to account for this. I wanted to make a continously variable manifold to account for this at all RPM.
Doing quick calculations, I figured at 1000 rpm, the pulse would need to travel something like 50m before the valve opened again. Obviously you can't design an intake system that large. At high rpm obviously that gets cut to a reasonable number. Anyways, I also figured that you could use "modes" of vibration. Say the pulse oscillates between the valve and the manifold 16 times. Now, I only need to design for a few meters.
I guess my question is how much of an effect can I measure at low RPM due to this? I think at high rpm, I should be able to get a noticable efficiency increase, but how much will these "oscillations" hinder gains?
If you need a quick overview of pulse tuning, I'd be more than happy to explain. Or google it yourself ;)
Anyways, thanks for the help
  • · Replies 19 ·
13K
  • · Replies 19 ·
37K
  • · Replies 48 ·
23K
