Force: Mass m Velocity Change from v1 to v2
The discussion centers on the definition of force in relation to mass and velocity changes, specifically from an initial velocity (v1) of zero to a final velocity (v2). A participant defines force as the product of mass (m) and the change in velocity (v2 - v1), which deviates from the standard Newtonian mechanics definition. According to established physics, force is defined as the rate of change of momentum, not merely the total change over time, which is referred to as impulse. This distinction is crucial for accurate understanding and application of physical principles.
  • Understanding of Newtonian mechanics
  • Familiarity with the concepts of mass and velocity
  • Knowledge of momentum and impulse
  • Basic grasp of physics terminology
  • Study the definition of force in Newtonian mechanics
  • Learn about the relationship between force, mass, and acceleration
  • Explore the concept of impulse and its applications in physics
  • Investigate advanced mechanics concepts, such as Chandranian mechanics, if interested
Students of physics, educators teaching mechanics, and anyone interested in understanding the fundamental principles of force and motion.
chandran
A block of mass m is resting on a frictionless surface and a push is given to it along the surface.
Now because of the push the velocity of the mass changes from v1 to v2. ofcourse v1 is zero. So this is what that push has done to the mass m. This push is called force. so force gives a result in which the mass m changes its velocity from v1 to v2.
I am defining force=m*(v2-v1).
Any thoughts on this further
so according to your definition, a push that makes the velocity of the mass go from v1 to v2 in 1 second is the same force as a push that makes the velocity of the mass go from v1 to v2 in 4 hours. this is not the way force is defined in Newtonian machanics.
However you may, if you please, define 'force' the way you did, and develop chandranian mechanics from there. Have fun :smile:
chandran, I'm not sure what your point is. As quasar987 pointed out, you are free to "define" terms any way you want, but this is not the standard definition of "force". In fact, m(v2-v1), "mass times the change in velocity" is normally called "impulse"- the change in the momentum over a certain time. Force is normally defined as the "rate[\b] of change" of momentum at a given instant, not the total change of a time period.
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 40 ·
  • · Replies 16 ·
  • · Replies 35 ·
