Will this 2.2 watt solar charger charge my booster pack?
The discussion centers on the feasibility of using a 2.2-watt solar panel to charge a 12-volt vehicle booster pack labeled "ES 2500." Users confirm that while the solar panel can provide some charge, it is primarily designed for battery maintenance rather than full charging. The panel outputs 2.2 watts, which translates to approximately 0.183 amps at 12 volts, insufficient for rapid charging. Concerns about charging efficiency and the potential need for alternative charging methods, such as connecting the booster pack in parallel with a car battery, are also raised.
  • Understanding of solar panel output specifications
  • Basic knowledge of battery charging principles
  • Familiarity with vehicle electrical systems
  • Knowledge of Ohm's Law and electrical resistance
  • Research solar panel charging efficiency for lead-acid batteries
  • Learn about connecting batteries in parallel
  • Investigate alternative solar chargers with higher wattage
  • Explore the specifications and charging requirements of the "ES 2500" booster pack
Individuals interested in solar energy applications, automotive enthusiasts, and anyone looking to understand battery charging methods using solar panels.
nobb
Hey.
I am not too knowledgeable on this topic so I was wondering if some of the knowledgeable folk here could help me out. Anyways, I have a 12 volt vehicle booster pack which is pretty discharged. There are no ratings on it except for the label that says "ES 2500." I am guessing that the 2500 may be the amp rating. There are two connectors on it, 2 clips, and a cigarette lighter socket. I have a solar panel which I bought from Canadian tire.
http://www.canadiantire.ca/assortments/...d=1408474396670271&bmUID=1124336620544
The panel is only about 2.2 watts and the product description mentions that it is good for battery maintenance. My questions is, if I hook up this panel to my booster pack, will it charge up my booster pack? I am aware that it probably will take a while, but it will happen right? Are there any concerns that I should be worried about? Thanks in advance.
Computer science news on Phys.org
The link you provided is dead.
Is this your booster pack:
http://www.all-cordless.com/bopa900peamp.html
Why are you using a solar panel if you can just hook up the booster pack to the cigarette lighter?
It says the charger requires 500 mA so if the solar panel outputs 2.2watts of energy you need 4.4 Volts or 8.8 Ohms of resistance.
Thanks for your reply. Yes, that is my booster pack. I am using a solar panel because that is what is availiable to me (I do not have the original charger). Could I just charge the pack by running my car then hooking up the booster pack in parallel with the main car battery?
18K
