Proving Cauchy Sequences in the p-adic Metric
The discussion revolves around proving that the sequence \{p^n\}_{n\in\mathbb{N}} is Cauchy in the context of the p-adic metric on the rational numbers. Participants are examining the properties of this sequence and its behavior under the p-adic norm.
  • The original poster attempts to establish the Cauchy property of the sequence using the definition of the p-adic metric. Some participants question the distinction between the sequence itself and the sequence of its partial sums, suggesting a potential mix-up in the reasoning presented.
The discussion is ongoing, with some guidance provided regarding the nature of the sequence and its limits. Participants are exploring different interpretations of the sequence's behavior in the p-adic context, particularly focusing on the definitions and properties involved.
There is a noted confusion between the sequence and its partial sums, which may affect the understanding of the Cauchy property being discussed. The implications of the p-adic norm and the behavior of the sequence as n approaches infinity are also under examination.
Oxymoron
Question
Consider the sequence [itex]\{p^n\}_{n\in\mathbb{N}}[/itex]. Prove that this sequence is Cauchy with respect to the p-adic metric on [itex]\mathbb{Q}[/itex]. What is the limit of the sequence?
Solution
Let [itex]p_n = 1 + p + p^2 + \dots + p^{n-1}[/itex]. Then we have
[tex]|p_{n+k}-p_n|_p = \left|p^n + p^{n+1} + \dots + p^{n+k-1}\right|_p[/tex]
[tex]= \left|p^n(1+p+p^2 + \dots + p^{k-1})\right|_p[/tex]
[tex]= \frac{1}{p^n}[/tex]
So for any [itex]\epsilon > 0[/itex], we can choose an [itex]N\in\mathbb{N}[/itex] such that [itex]p^N \geq \frac{1}{\epsilon}[/itex], so if [itex]n > N[/itex] we have
[tex]|p_{n+k} - p_n|_p < \frac{1}{p^N} \leq \epsilon[/tex]
Therefore [itex]\{p^n\}_{n\in\mathbb{N}}[/itex] is Cauchy.
ii) Since
[tex]|p^n|_p = \frac{1}{p^n} \rightarrow 0 \quad \mbox{as} \quad n\rightarrow \infty[/tex]
the limit
[tex]\lim_{n\rightarrow\infty}^p p^n = 0[/tex]
Hence this sequence is actually a null sequence with respect to the p-adic norm.
You've shown the corresponding sequence of partial sums is Cauchy, not the sequence itself. In your other p-adic thread you showed the terms, not the partial sums, go to zero. You seem to be mixing the sequence itself with the sequence of partial sums (or you swapped your replies).
  • · Replies 17 ·
