What is Overdrive on a Truck? | 1993 GMC Sierra V6
  • Thread starter Thread starter Jeremy
    Truck
The discussion revolves around the function and usage of the overdrive feature in a 1993 GMC Sierra V6 truck. Participants explore the mechanics of overdrive, its impact on engine RPM and fuel efficiency, and the appropriate conditions for its use, including driving scenarios and vehicle performance considerations.
  • One participant expresses confusion about the difference between "drive" and "overdrive," suggesting that overdrive reduces engine RPM and increases gas mileage.
  • Another participant equates overdrive to a manual 4th gear but admits a lack of mechanical expertise.
  • Several participants discuss the conditions under which overdrive should be used, with some suggesting it is best to keep the truck in overdrive unless climbing steep hills or towing heavy loads.
  • One participant highlights that shifting to drive may be necessary in certain situations to prevent erratic gear shifting.
  • Another participant provides a technical explanation of how an automatic transmission operates, including the role of the torque converter and its efficiency implications.
  • There is a discussion about the historical context of overdrive gears, with differing opinions on whether they are a recent invention.
  • Concerns are raised about the durability of certain automatic transmissions when frequently using overdrive, suggesting that some vehicles may perform better if overdrive is avoided in specific conditions.
Participants do not reach a consensus on the best practices for using overdrive, with multiple competing views on when it should be engaged or disengaged based on driving conditions and vehicle specifics.
Some participants mention specific vehicle models and their transmission characteristics, indicating that recommendations may vary based on the type of transmission and its design. There are also references to potential inefficiencies associated with automatic transmissions that may affect fuel economy.
Jeremy
I may be lazy looker but this seemed like the best forum for this question. i just hope there are car people here.
i have a 1993 GMC sierra V6 truck (dark blue, in case you were wondering). On the "shifter" i have the option to drive in "drive" or "overdrive."
Now i don't really understand the difference too well. All the sites i have read to a rather poor job of explaining it: usually they use words that i don't understand or they are too make/model-specific for it to apply to me.
on my way to school every morning, i drive 4 minutes at about 60 mph and roughly 4 minutes at 45-55. The road is relatively straight with little to no traffic or stoplights until the very last minute or so.
From what I have understood, overdrive actually REDUCES the work done by the engine (in terms of RPMs) and INCREASES the gas mileage. Could someone outline what is going on AND tell me when (if at all) i should use OD (including in other situations). gas costs $2.65 and my truck is 12 years old...I need to become as efficient as possible.
I always thought OD is the equivalent of the manual 4th gear. But I am not a mechanic. Have thought about calling a car talk radio show and asking your question there?
This should be posted in engineering
*Moved into General Engineering*
Gas mileage decreases rapidly at speeds above 60 mph. I use overdrive when I'm cruse'in at 70+ {which is often}When you use overdrive gearing, your car's engine speed goes down. This saves gas and reduces engine wear.
Your tranny shifts into a higher, larger gear, which reduces you engine rpm, increases fuel milage and hence is called 'overdrive'.
Regards,
Nenad
so how should i be using overdrive? do i need it on my daily 10 minute commute to school, or only when i get going on a highway for half an hour? should i be shifting from D to OD while i am driving (i understand shifting between certain gears while pressing the gas can damage the transmission...maybe not in this case though).
the car is an automatic by the way.
thanks for the help.
Basic operation of automatic transmission cars
The question more appropriately might be "When should I not use overdrive?". In an automatic, the car selects the appropriate gear-ratios based on data such as engine vacuum. You should always drive an automatic in overdrive, no matter the speed, unless conditions warrant otherwise. This allows the car to select from the full range of gear-ratio options. Shifting down to drive restricts the range the car is allowed to select from. If you happened to be climbing a moderate hill and the car was shifting between drive and overdrive, you might want to temporarily shift it into drive so the car stops hunting between gears. If you happened to be climbing a hill while towing a 5,000 lb trailer, you might want to temporarily shift into a gear lower than drive.
Also, some people like to shift down when descending hills. Shifting from overdrive to drive will provide a moderate amount of engine braking at typical freeway speeds.
The etymology of 'overdrive'
Steeper, actually.
"Drive" refers to direct drive, which means a transmission ratio of 1:1, which means the output of the transmission is spinning at the same rate as the input. Most of the gears in a car are underdrive gears, which means they are below 1:1 (shallower or flatter than direct drive) and allow the engine to spin faster than the output of the transmission, and for years past the top gears on cars were typically 1:1 ratio, which is to say they were direct drive.
An overdrive gear is a recent invention that is even steeper than a drive gear, and hence provides a gear ratio of greater than 1:1. Some high-end cars, such as the modern Corvette, have two overdrive gears. See the gear-ratio table here:
http://www.corvettesbyrickdaniel.com/C6SPECTS.html
According to that table, the two C6 6-speed transmission options provide 3 underdriven gears (gears one through three), one drive gear (fourth gear), and two overdrive gears (gears five and six).
hitssquad said:
Steeper, actually.
I don't see what is wrong with my statement that your engine RPM's decrease when you shift into overdrive. You stated yourself that the ratio mover from a higher one to 1:1.
Regards,
Nenad
hitssquad said:
An overdrive gear is a recent invention that...
I wouldn't call it recent. Overdrive has been around for many years. I am not referring to aftermarket add-ons either.
alright so i should basically always keep the truck in overdrive except:
when climbing a long steep hill and it is switching gears erraticly
when i am towing/have bed full of rocks and am climbing a rather steep hill
thanks for all the help guys. my truck and i thank you.
You might want to ask someone more in the know about this. Ford AOD's(not AOD-E's) have a weak OD band so it's actually better to drive them in D while in the city and only go into OD when driving for an extended time greater than 45. Older VW auto's had a similar problem. Actually, there are a lot of auto's out there that die prematurely due to weak OD servos. Do you know what type of trans you have(I'm guessing a 700-R4)? If you do have a 700 then OD all the time is probably a safe bet.
I don't deal with GM's that often so I can't say off the top of my head what the best strategy is but simply saying OD always is wrong because there are transmissions out there that last longer if you avoid OD.
My 2 cents. Good luck.
An automatic transmission in a car or truck has a "torque converter" which is essentially a hydraulic pump and motor combination. It allows the input and output shafts to differ in RPM slightly, so that one can idle in gear at a traffic light or change gears automatically. But it does this at a cost, the cost being lower efficiency:
All automatic transmissions use a torque converter to couple the engine and transmission. Torque converters are not 100% efficient. Some energy is lost between the input (the impeller) and the output (the turbine) sections. ...
This action aids an automatic transmission vehicle's acceleration capacity. Once turbine speed is approximately 90% of impeller speed, the one-way clutch race spins on its own axis. At this point, the converter is said to be "coupled hydraulically." Under these conditions, up to 10% of the engine's output power could be lost to the torque converter's internal slippage. This accounts for most of the mpg difference between a standard and automatic transmission vehicle. This energy loss is transmitted to the vehicle's radiator and shed as heat.
The overdrive feature locks the input and output shafts so this loss is eliminated and you can get higher gas milage.
Recently developed torque converters have had a "lockup" feature added to reduce this energy loss and improve mpg. This lockup feature will not engage until the vehicle reaches approximately 40 mph.
Ref: http://www.leeric.lsu.edu/bgbb/7/ecep/auto/f/f.htm
faust9 - the 700R4 had plenty of improvements made to it over the years, the 89+ seem more reliable with an improved pump but they were never as good as the 4L60E. And even with that, my best friend from high school went through three 4L60E rebuilds in his regular cab 2wd S10 with the 122HP 4cyl and the most he towed was a jet ski! It just seemed the mountains going midwest-west coast killed it without any other effort needed. Its not like those GN guys who have done miracles with the little 200R4 metric tranny haven't shown how durable things can be made for short-term duty, but most engineers would see the impractical price that comes with it and how many of those cars are driven in traffic much less go 100,000+ miles?
While on the topic though, I think it was Motor Trend who interviewed some NYC cab drivers about what they needed to do to their cars. Hard to believe a Crown Vic or Caprice could go 600,000 miles on 3 trannies and 2 engines, but there was more than one example of guys making it 350,000 on one tranny, in NYC! Reminds me of a Mad magazine sketch about a manufacturer who has a customer that bought their product 30 years ago and never had a problem with it buying it to find out what they did wrong to make it last so long without needing a replacement. :smile:
For the OP, since you are not sitting in traffic you have really nothing to worry about. Heat is generally what kills an automatic transmission, and driving down the road the cooling should be plenty adequate for long life. Your mileage will improve a lot though, the 30% reduction in engine RPM will make a big difference in the overall mileage. And you could emprically test it too, try one week without OD and compare.
You should make sure other things are up to spec too, check the air filter and tire pressures kind of thing. Even an O2 sensor can make a big difference, when they go bad on my TransAm the mileage goes from 28/20MPG to something like 20/16MPG and that is a shocker when you're driving like granny and the needle still flies towards empty! Luckily I have 4 O2 sensors to go bad (1996) and they are near impossible to replace since the crowsfoot wrench can't break them loose, so the garage sings with expletives once every couple years or so...
Overdrive is any gear ratio beyond that of direct drive, which in turn is 1:1. The lockup feature is independent of the overdrive feature.
What overdrive is and is not
Allowing relative decrease in engine RPMs is not what defines an overdrive gear.
Your engine RPMs decrease when you shift into second gear from first gear. That does not make second gear an overdrive gear. Only having a gear ratio beyond that of drive, 1:1, makes a given gear an overdrive gear.
Probably not, since 1:1 is defined as direct drive, not overdrive.
Thanks for pointing that out; some of the foregoing posts had me pulling my hair out. I remember that when I first started into the street scene, there was an aftermarket unit called the Honodrive (sp?) that was installed right behind the tranny and gave an extra shift option. Also, 4th gear in my '72 Roadrunner (A833 tranny) is a .73:1 overdrive rather than direct drive. My former friend from the old days actually experimented with mounting a 3-speed manual tranny backward in line with the main tranny to give multiple overdrive ratios, but trying to clutch the thing proved a little too impractical. :rolleyes:
That reminds me of the street racers who put an extra (rear wheel drive) engine and transmission in the back of a front-wheel drive car -- to make a sleeper. In the one I read about I recall that at least one of the two trannies was an automatic.
Man, but I love Q-ships! The first one that I ran into was a stock-looking VW bug at the Burger King in Windsor. It was idling a bit suspiciously, so I asked the guy what was in it. "Just the stock bug motor", says he, and pops open the engine bay to reveal just that. It took a couple of seconds to realize what was wrong—the thing wasn't running. After a grinning prod, he took me around to the front and popped the trunk. There before me was a full-boogie Boss 302 lumping away in wait for a victim.
The one that I was trying to do myself didn't work out because the body that I had on hand was too far gone. It was a '69 DS19 Citroen. My plan was to mount a mid-engine 392 hemi in the back seat tied to a flipped-over Toronado transaxle, then tint the windows. :devil:
You had a Citroen DS?
My respect for you has just tripled.
Hi Brewski;
I unfortunately never had the pleasure of owning one that was in useable condition. My cousin had owned several, and bought this specific one in partnership with another fellow as a restoration project. They had a falling-out, the other guy bailed, and Logan couldn't afford to do it himself. Rather than toss it into the boneyard, he gave it to me. My plan at the time was to transplant the suspension system into my Roadrunner and make the DS into the aforementioned 392 Q-ship. Unfortunately, the body was far too rusted out to do anything with, even though I had intended to put a full chrome-moly frame under it. On the other hand, trying to transplant the suspension turned out to be virtually impossible. I assume that you have some familiarity with the hydraulics systems in those buggers and realize the complexity of such an operation. I'd still love to have a driveable DS though, without modifications.
I suppose I was just being a bit naive; I didn't realize that the DS would have made it over to your continent. There's one which lives a few miles away from me, it's stunning. Apparently not an easy car to own (and yeah, those Citroen hydraulics are a nightmare), but it's cars like that which make young boys stop and stare in the street with their jaws on the floor.
What's a Q-ship? Stealth car? I had some plans for my Citroen actually, dropping the VTS engine into it with a moderate turbo, and removing the bodykit, VTR badges, and going to plain steel wheels instead of the alloys. That would have been fun, but I don't think my insurance company would approve...
Q-ship is the alternate word for what is more commonly called a 'sleeper'. It simply means a wolf in sheep's clothing, such as the aforementioned bug. You leave the car as stock as possible on the outside, and build the drivetrain to the nuts. Even better, if you're young, is to put on a couple of cheapo bolt-on mods like a hood scoop and fancy rims, so that everyone thinks that you're pretending to have a hot car when you don't. The name derives from the Royal Navy. When pirates became too much of a nuissance, they sent out full-bore warships disguised as trading vessels. When the pirate ship threatened, they dropped the fake hull on pulleys to reveal multiple banks of cannon which then proceded to shred the pirates into rat salad. They were officially known as Q-ships.
I don't know any of those terms that you mentioned in regard to your Citroen. The DS19 is the only one that I'm familiar with, other than the Maseratti (sp?) incorportation of Citroen suspension technology back in the 70's.
Another fine example of a Q-ship, however, would be a buddy of mine who transplanted a Ferrari drivetrain into a VW Sirocco and left it looking stock. :biggrin:
  • · Replies 39 ·
21K
