Understanding Spin of Particles & Atoms: FAQs
  • Context: Graduate
  • Thread starter Thread starter Nim
    Particle Spin
The discussion centers around the concept of "spin" in physics, particularly in relation to particles, atoms, and composite systems. Participants explore the definitions, implications, and distinctions of spin in various contexts, including quantum particles, atoms in Bose-Einstein condensates (BEC), and superconductors.
  • Some participants express confusion about the definitions of spin, questioning the differences between the spin of quantum particles and that of atoms or composite systems.
  • It is noted that the spin of composite particles, such as Cooper pairs in superconductors, depends on the spins of the elementary particles that constitute them.
  • Participants discuss the distinction between intrinsic spin and orbital angular momentum, with some asserting that "spin" typically refers to intrinsic angular momentum.
  • There is a claim that bosons can have either integral or zero spin, while fermions have a spin of 1/2, illustrated with examples like alpha particles.
  • One participant provides a description of how much a particle must turn to appear the same again, detailing the degrees associated with different spins.
  • Questions arise regarding the terminology used, particularly the distinction between quantum particles and classical particles, with some participants clarifying the meaning of "quanta" and "quantum."
  • There is a query about whether a BEC represents the largest entity with spin, prompting further exploration of the nature of spin in larger systems.
Participants do not reach a consensus on the definitions and implications of spin, with multiple competing views and ongoing questions about the nature of spin in different contexts.
Some discussions highlight limitations in understanding the terminology and concepts, such as the distinction between quantum and classical particles, and the implications of spin in composite systems versus elementary particles.
Nim
I don't quite understand what a "spin" is. My dictionary has two definitions.
11. PHYSICS angular momentum: the intrinsic angular momentum of an elementary particle or system of such particles independent of its motion.
10. PHYSICS quantum property of angular momentum: the quantum property or number of an elementary particle that is a measure of its intrinsic angular momentum and magnetic moment.
Is there a difference between the spin of a quantum particle and the spin of an atom, or combined atoms in a He3 BEC, or combined electrons in a superconducter? I would think an atom couldn't fall into the same category as a quantum particle or a photon at that. Quantum bosons are said to be force-carries, are other bosons force-carries too?
Also, what can or cannot have a spin? I thought only quantum particles had a spin at first. And then I found out that atoms can too. And then I found out that two atoms together can have a spin. But I guess that is only at really cold temperatures, why can't atoms combined in a solid have a spin? Why doesn't a solid itself have a spin? What is that largest thing that has had a spin before, just two atoms connected together?
The spin of a composite particle depends on the spin of the elementary particles that make it up. For example, the combined electrons in superconductors that you mentioned are called Cooper pairs. They are made of two electrons, each with spin 1/2. When they join together, one is spin "up" and the other is spin "down", so they net spin of the Cooper pair is 0.
Originally posted by Ambitwistor
"Spin" is just another word for "angular momentum". So anything can have "spin". Sometimes the word is used implicitly to refer to intrinsic spin, which is the angular momentum of an elementary (non-composite) particle.
By the way, what is a non-quantum boson?
Tell me if I'm wrong, but I always thought that spin (in the general sense, as obviously spin angular momentum is different to orbital angular momentum in quantum terms though of course they both contribute to the angualr momentum of a particle) was different to orbital angular momentum.
When the word spin is used, it usually refers to the intrinsic angular momentum S of a particle, and not the orbital angular momentum L.
I meant in general terms, for example someone might talk about the spin of a neutron star in a binary system.
A boson that isn't a quantum particle would be an alpha particle. Fermions have a 1/2 spin. Bosons have a 0 or intregral spin. The two protons and the two neutrons in an alpha particle combine to make a boson because 1/2 + 1/2 = 1.
Spin means how much a particle must turn to look the same again.
Spin 1/2: 720 degrees (two turns)
Spin 1: 360 degrees (one turn)
Spin 2: 180 degrees (half turn)
Spin 3: 90 degress (1/3 a turn)
The higher the spin, the less it has to turn to look the same again. I don't really know how they turn them though, especially so precisely.
Oops, now I see what you meant. I was just referring to QM :wink:
This is true, but it can be dangerous to think about particles "spinning" about some well-defined axis.
This really doesn't answer Ambitwistor's question.
Why do you think a boson is "nonquantum"?
The reason one would ask is that neither Bose-Einstein nor Fermi-Dirac statistics describe ensembles of classical particles. They are both "quantum".
I thought a quantum particle was an elementary particle. Isn't quantum the smallest amount of something? Am using the terminology wrong?
You might me thinking of quanta. A quanta is a small piece of something. It is commonly used to describe something that is not continuous but quantized (hence the name). For example, the quanta of the electromagnetic field is a photon. Similarily, phonons are the quanta of vibrations inside crystal lattices.
No... Quanta is simply plural for Quantum.
You say tomato, I say tomato... I usually just use quanta for everything, singular or otherwise. I guess I should pay more attention :wink:
BTW krab, I noticed in your profile that you work at TRIUMF. Very cool. My thesis research is currently based on μSR experiments conducted there.
So is a BEC the largest thing with a spin, that is, something that is either a fermion or a boson?
  • · Replies 16 ·
  • · Replies 49 ·
