| Thread Closed |
Sonic flow |
Share Thread | Thread Tools |
| Aug20-05, 07:56 AM | #1 |
Sonic flow
If subsonic flow is accelerated in a converging duct to mach 1 and then the duct is further converged, choked flow will occur. Will flow at the exit of the duct be compressed as the volume flow rate is decreasing but the mass flow rate has to remain the same.
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Aug21-05, 06:25 AM | #2 |
Can anyone help please?
| Aug21-05, 07:25 AM | #3 |
Hey Sid. This is a bit outside my area of expertise, but I believe supersonic wind tunnels don't operate quite like you're suggesting.
So to answer your question, the gas does not compress further after the point at which sonic velocity is reached because after this point, the duct diverges. In fact, I don't think it will compress as it enters the convergent section either. The first law of thermo is relavent here, just not sure how to apply it for this type of flow. |
| Aug21-05, 09:15 AM | #4 |
Recognitions:
Sonic flow |
| Aug21-05, 11:13 AM | #5 |
| Aug21-05, 11:43 AM | #6 |
Thank you for the replies.
If the gas was say being pumped by a piston, then will the piston feel the pressure wave? I'm guessing that since it is travelling upstream, the piston would feel the pressure wave. Are there any good books which deal with such flows? I don't mean a book on aerodynamics but a book which solely deals with airflows, jets, diffusion, etc. |
| Aug21-05, 01:28 PM | #7 |
Mentor
The subject you're looking for is called "gas dynamics" and it deals with sonic/supersonic flow through nozzles.
| Aug21-05, 06:55 PM | #8 |
How can the pressure wave travel upstream?. Well, the sonic flow is an unstable one. I mean, I will bet sonic conditions doesn't exist in reality. The same happens with critical flows in open channel hydraulics. How do you define "sonic flow"? A flow such as M====1.0000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000 00000000000.??? Around sonic conditions there will be always fluctuations. To say the truth I don't dare to speak more about this stuff, because I really have reached a point here I cannot answer you with total assurement. This question could be dealed by means of gasdynamics steady equations everybody knows here, but I am not going to do that, because I would be lying you. Your question has a trick, because it implies an unsteady regimen, and given a geometry variation as you mentioned, only upstream fluid can feel it by means of a pressure wave, reshaping so all the fluid field. It must be on that way. During the unsteady process the sonic conditions could be destroyed momentarily, in the former sonic section, to be re-established in the new one downstream. You know sidgalt, I really know one can sometimes be confused imagining flow configurations and trying to explain it with the steady one dimensional gas dynamics equations that every us learn in an undergraduate course. One must look farther in order to explain some other difficult flows. Anyway your questions are always welcome. ![]() EDIT: I have a question for you. What are you studying and where?. It is only curiosity. Please tell us. |
| Aug21-05, 08:28 PM | #9 |
| Aug22-05, 05:21 AM | #10 |
| Aug22-05, 06:36 AM | #11 |
| Aug22-05, 09:36 AM | #12 |
When I was 15 years I didn't know anything of what you currently ask or talk about in this forum. I was only concerned of being a famous football player. If you keep on being interested on this stuff at such early ages, surely you will do something important in the future with your life.
| Sep8-05, 07:02 AM | #13 |
Thanks!
BTW, I was thinking about this a bit more and realized, wouldn't decreasing the duct diameter more result in Prandt-Meyer compression waves which will increase the static pressure but decrease the total pressure? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Sonic flow
| Transition from pipe flow to open channel flow | Mechanical Engineering | 6 | ||
| Can an inviscid flow rotational? Potential Flow? | Mechanical Engineering | 2 | ||
| Sonic reflexes | Biology | 4 | ||
| Help on sonic boom | Mechanical Engineering | 12 | ||
| sonic booms | Introductory Physics Homework | 1 | ||
