| Thread Closed |
Solutes vs. Solvents |
Share Thread | Thread Tools |
| Nov8-03, 01:13 PM | #1 |
I'm in College Preparatory Biology in high school(9th grade) and my friend was trying to prove my teacher wrong(it's fun :P).
He said that a solute is the same thing as a solvent. According to his dictionary, a solute is a substance that can be dissolved into another substance. Also according to his dictionary, a solvent is a substance that can dissolve anyother substance. My friend looked up dissolve and it said "the act of changing the purity of a substance by causing it to pass into another substance" My friend argued that if you pour Kool-Aid into water, the Kool-Aid would be the solute, and the water would be the solvent, right? If you pour water into the Kool-Aid, however, the water would be the solute, and the Kool-Aid would be solvent. So Kool-Aid = Solute or Solvent and Water = Solute or Solvent. |
| Nov8-03, 02:36 PM | #2 |
Recognitions:
That might be a bad example because water doesn't disolve in kool aid.
You should probably use something different like alcohol and water, or gasoline and oil if you want solution in both directions. |
| Nov8-03, 05:52 PM | #3 |
Everything is soluble in everything else? Close --- needs some qualifications regarding stabilities at T, P, and chemical potentials of solvent and solute.
Water in Kool-aid? Sure --- think about dry Kool-aid vs. the stuff that's been sitting in the cupboard all summer in 100% humidity. Pouring water into Kool-aid that's already in solution? Nope, that's a dilution process. Be careful (or caution your friend to be careful) using a dictionary to support scientific arguments --- Merriam Webster, Roget, and the Oxford are NOT recognized authorities on the very specific uses of words within scientific contexts. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solutes vs. Solvents
| Boiling solvents | Chemistry | 11 | ||
| Osmosis, Solutes, and Solvents | Biology, Chemistry & Other Homework | 1 | ||
| Solutions compared of solutes and solvents | Chemistry | 1 | ||
| fats and solvents | Biology | 9 | ||
| Science experiment: density of solvents, more? | Introductory Physics Homework | 0 | ||
