Is Displacement Always Zero in Circular Motion?
  • Context: High School
  • Thread starter Thread starter SVG84R
    Displacement Zero
The discussion centers on the concept of displacement in circular motion, particularly whether the displacement is zero after completing one full revolution. Participants explore the definitions and implications of displacement, velocity, and acceleration in this context, touching on both theoretical and practical aspects.
  • Some participants assert that displacement is zero after completing a revolution since the final position coincides with the initial position.
  • One participant clarifies that displacement is a vector quantity and distinguishes between the zero vector and zero as a scalar.
  • Another participant provides a mathematical representation of displacement in circular motion, concluding that it is zero after a complete revolution.
  • Some participants discuss the distinction between displacement and traversed distance, with one suggesting that a friend's analogy of extending the circle into a straight line is flawed.
  • A participant raises a question about the relationship between linear and radial acceleration in circular motion, particularly how to apply kinematic equations when displacement is considered zero.
  • Another participant emphasizes that while the average velocity and acceleration over a complete revolution are zero, instantaneous acceleration is not zero due to real forces acting on the object.
  • One participant notes that angular displacement is not zero, while the x and y displacements are zero when returning to the starting point in counterclockwise motion.
  • There is a discussion about the nature of tangential velocity in circular motion and how it relates to direction changes when returning to the starting point.
  • Some participants question the application of kinematic equations in circular motion, particularly regarding the treatment of displacement and linear acceleration.
Participants generally agree that the displacement is zero after one complete revolution in circular motion. However, there are competing views regarding the implications of this conclusion, particularly concerning the relationship between displacement, distance, and acceleration. The discussion remains unresolved on some aspects, particularly the application of kinematic equations in this context.
Participants express uncertainty about the definitions and relationships between displacement, distance, and acceleration in circular motion. There are unresolved questions about how to apply kinematic equations when considering circular paths and the implications of treating circular motion as linear motion.
This discussion may be useful for students and enthusiasts of physics, particularly those interested in the concepts of motion, displacement, and acceleration in circular dynamics.
SVG84R
erm just want to clarify this.If one were to move in a circular motion,and u complete one revolution thus meaning you come back to the same point to where you started off,is your displacement equals to zero??
Yes! Technically, it is the zero vector which is not the same as zero (a scalar) since vectors and scalars are different entities.
Displacement is defined as the difference between the final position and the initial position of the object, regardless of the path the object follows in between. So if the object ends up returning to its initial position, its net displacement is zero.
Mathematically, let [itex]r[/itex] be the radius of your circle, which defines the motion of your object. Circles are 2D figures, so we can represent the object's motion in a plane; I will use 2D Cartesian for this example. The location of its center is irrelevant (as it remains constant), so let the center be at the origin (0,0).
Therefore, the object's position can be represented via the position vector
[tex]\vec P = r\left( {\hat i\cos \theta + \hat j\sin \theta } \right)[/tex]
where [tex]\hat i[/tex] & [tex]\hat j[/tex] represent unit vectors in the [itex]x[/itex] and [itex]y[/itex] directions, respectively.
Simply put, you can represent the object position as the head of a position vector whose tail is the center of the circle, which we set at (0,0). It has a magnitude [itex]r[/itex] with an "[itex]x[/itex]" component equivalent to [tex]r \hat i \cos \theta[/tex] and a
"[itex]y[/itex]" component equivalent to [tex]r \hat j \sin \theta[/tex], where [tex]\theta[/tex] is the angle swept counterclockwise from the positive x-axis, with the vertex being the origin.
Displacement is a vector quantity associated with a change in position. Where [itex]\vec P[/itex] is the position vector, displacement is defined as [itex]\Delta \vec P[/itex].
In a "complete revolution", the [tex]\Delta \theta = 360^\circ = 2\pi[/tex]. If we let [tex]\theta _0[/tex] represent the initial angle relevant to the object's position vector, then in a complete revolution:
[tex]\Delta \vec P = r\Delta \left( {\hat i\cos \theta + \hat j\sin \theta } \right) = r\left\{ {\left[ {\hat i\cos \left( {\theta _0 + 2\pi } \right) + \hat j\sin \left( {\theta _0 + 2\pi } \right)} \right] - \left( {\hat i\cos \theta _0 + \hat j\sin \theta _0 } \right)} \right\} = 0[/tex]
Thus, you will have ZERO displacement.:smile:
And when you think about it, much of what I wrote is completely unnecessary! Though it does, "sort of" provide an answer from a mathematical perspective...err, though it might have been unnecessary. :frown: sorry...
cool i needed a proof like this,thx guys.well what set me pondering me was that my friends said if u could imagine the circle as a string,and now you take it and separate and extend into a straight line,you will get displacement.This of course doesn't make sense.In addition, one of them pointed out that when the particle comes back to the same point in a circular motion,its tangential velocity is pointing in the same direction as it first started off.Now what he claimed was that when one walked in a straight line,in order to move back to where you started off,you have to change direction,hence your velocity must point in the opposite direction.That was what set me thinking.lol.anyway thanks!
I believe your friend muddled up the concepts of displacement and TRAVERSED DISTANCE.
Perhaps he was thinking about a displacement which causes something along the way.
ok i think i need to revist this question.let say its a circular motion with both linear accleleration and a radial acceleration,and the object starts from rest,i'm told to find the angle made by the total acceleration with the radial acceleration after the object completes one round of revolution.
we know that the radial acceleration is a=v^2/r,but what about the linear acceleration??
what my tutor did and set me puzzling was that he used kinematic equation:
v^2=u^2+2as,to solve for the linear acceleration.Hence s,which is the displacement,turns out to be 2pi*r which is the circumference of the circle.How can this equation be used if we conclude that the displacement is zero for one revolution?can we treat the linear portion as a particle moving in a straight line?
can someone enlighten me??
Treat "s" as the distance along the circumference measured from the starting point. All the usual kinematic formulas for uniformly accelerated motion apply (assuming the tangential acceleration is constant).
Yes, the displacement of the object after making one complete revolution is zero. This means that the average velocity (and acceleration) over such a cycle is zero. This should make sense: the object keeps coming back to where it started.
But what you want to know is not the average acceleration, but the instantaneous acceleration at some point. This is certainly not zero: Real forces are acting to accelerate that object. To find the instantaneous acceleration, it helps to treat the radial and tangential components separately.
Displacement is the difference between two points in (any metric) space. Because of the time dependence in dynamics, it's customary to think of the displacement as a function of time. bomba923 got it right.
The tricky point stems from the coordinates involved. After a complete revolution, no matter what the speed or acceleration or amount of backtracking, the angular displacement will be 2pi (unless you end up going clockwise to the starting point). But, the usual x and y (and you can always set the starting point at x=0, y=0, angle=0) are periodic functions of the angle, and thus are always zero for the
angle=2*integer*pi, as can be seen with plots of x and y. So, the angular displace ment is not zero, but the displacements in x and y are zero whenever the particle moves with counterclockwise motion and arrives at the starting point.
Regards,
Reilly Atkinson
He's right. With a circle a similar thing happens, if you look at the opposite side of any circle you will note that the tangential velocities point in opposite directions. For example, if you say that on the right side of the circle the up direction for a tangential velocity starts things off, draw a 180 degree line to the other side of the circle and you will find that the tangential velocity there is pointed downward exactly equal and opposite in both direction and magnitude to the one on the right. Take a pencil and draw a circle slowly to see what I mean, while you are on the right side of the circle your hand is moving "upwards" and while on the left side it is moving "downwards." The two motions act to cancel each other, and you end up right back where you started after you travel the full circle.
v^2 means v.v (vector dot product) which is a scalar, as is u^2 = u.u ;
but since the a vector points inward toward the circle center,
while the s vector (displacement) is along the path of the circle, a.s = 0 .
( ie, No Work is done by the force that causes the centripetal acceleration)
Reilly: isn't displacement supposed to be a vector, rather than a change in coordinate?
hmm so if we want to find the linear acceleration,we can apply kinematics equation solve for it?
But however,can we treat the circle as a straight line??Arent we suppose to take our position with respect to the cirlce?hence the displacement equals to zero??
is there any other way than using the kinematics equation to solve for the linear acceleration?? say can we differentiate the tangential velocity wrt to time to get the linear acceleration??
Assuming the tangential acceleration is constant, the usual kinematic equations apply.
The tangential velocity at any time is just [itex]v_t = r \omega[/itex]; thus the tangential acceleration is [itex]a_t = r \alpha[/itex].
Even better, try this. Take bomba923's expression for the position vector:
To find the velocity, take the first derivative; to find the acceleration, take the second derivative. The acceleration will have two components: (1) a radial component equal to the centripetal acceleration, and (2) a tangential component giving the tangential acceleration.
lightgray --Yes displacement is a vector, and, I apologize for my sloppy, but somewhat standard usage.
Again, the speed, direction of motion, etc. have little to do with the displacement at any given time -- except to tell you how the object got to where it is. The confusion, once again as clearly as i can say it: it all depends on the coordinates you use. For the angular motion, one should do arithmetic modulo 2pi -- normally we do this with the tacit agreement that 10pi is the same is 2pi. This matter is discussed in as much detail as you want in freshman physics texts, some calculus texts,and, in fact, in more advanced mechanics texts dealing with generalized coordinates. Very basic stuff.
Regards,
Reilly Atkinson
hey now, You don't know if the displacement is zero in that question.
He did not clarify in what sphere (frame) of reference are we talking. The sphere (frame) of reference may have changed while we were traveling the circle.
16K
  • · Replies 34 ·
