Can Computers Learn to Compress Data Like the Human Brain?
The discussion revolves around the concept of whether computers can learn to compress data in a manner similar to how the human brain processes and remembers information. Participants explore theoretical approaches to data compression, the potential for computers to understand text meaningfully, and comparisons to existing compression algorithms.
  • Some participants propose that the human brain compresses information by memorizing meaningful text rather than raw data, suggesting a model for computer data storage.
  • Others argue that creating a computer that mimics human memory, which relies on associations, would be necessary for this approach to work effectively.
  • A participant suggests developing a database of common phrases to improve data compression by referencing these instead of storing raw data, although they note limited savings in practice.
  • Concerns are raised about the interpretation of data when reconstructed by a computer, which may not accurately reflect the original text.
  • Another participant mentions existing MPEG compression schemes, highlighting their lossy nature and drawing parallels to how the human brain processes information, suggesting that MPEG-7 aims to understand and describe content rather than just compress it.
  • There is a discussion about the limitations of lossy compression algorithms, with some participants noting that they may not preserve original data perfectly, which contrasts with the idea of lossless compression.
  • One participant emphasizes that while the human brain may use lossy methods, it selectively remembers details, which could inform more efficient compression algorithms for computers.
  • Concerns are raised about the fundamental differences between human cognition and current computer processing capabilities, particularly regarding linear and finite-state operations.
Participants express a range of views on the feasibility and implications of teaching computers to compress data like the human brain. There is no consensus on the effectiveness of proposed methods or the comparison to existing algorithms, indicating ongoing debate and uncertainty.
Limitations include the unresolved nature of how to effectively implement a database for compression, the challenges of maintaining data integrity during reconstruction, and the inherent differences between human cognition and computer processing methods.
STAii
The other day i came across [Removed Broken Link], and while reading it i started thinking; "Why don't we human try to compress the things we learn before learning them, and uncompress them when we need to remember them ?".
Then i realized that the human brain finds it easier to memorize a meaningfull text than to memorize some bunch of letters and numbers that don't mean anything until they are uncompressed.
This gave me a new idea, why not to teach the computer to actually understand a text passage instead of saving it byte by byte ? Maybe this can allow the computer to use the disk storage a little better.
So what stops us from learning the computer to actually save text files the same way we memorize text files ?
(forget about other files (like pictures) for a second :smile:)
Computer science news on Phys.org
it's a cool idea, but wouldn't it require basically creating a computer that worked more like the human brain. remembering things by association and not just taking a byte by byte snapshot?
sounds like something neural network people would try to do.
It would probably be ok as long as you didn't mind the interpretation the computer gave when spitting back the info.
I had thought about something like this a while ago. The idea was that you develop a huge database that you have common passages or strings or whatever and the file you store cross references with the database so rather than compressing with an algorithm based on the actual file data, you find common patterns first then drag uncommon data to the database to use next time.
eg. a dictionary database that you store a symbol instead of words or common combinations of words in the file and use the database to reconstruct with no loss.
I was originally thinking about binary files and taking the repeated chunks, like in commonly used libraries, and storing them in a database. After some looking into it there wasn't really a huge saving. Probably only a few k on a small binary file.
Getting back to the first bit, the task of parsing and associating the text probably isn't impossible, but what you got at the end would only vaguely resemble the original text.
Raavin
First of all, thanks for the reply.
I was thinking about the same, making kind of a dictionary (that may get standard some day) with the sentences, words and phrases that are used over and over, but i didn't try to calculate how much this can be useful for the disk space (i assume if the data entries are quite long, it will be quite usefull (it also depends on the number of entries in the database, since more entries will mean more disk space only to save the entry index into the file).
And of course it will not really be easy to make this database, it will be even harder to update it globally !
Raavin, you said you were able to save some Kilobytes, but how
big was the engine that makes the uncompression ? (cause if the engine was not really big, this may get EXTREMLY usefull in boot sectors).
spacemanspiff, yes, i think we will need to understand the human brain more in order to make such a thing into reality (without using the database idea proposed by Raavin).
I never actually implemented an alorithm. I just manually compared chunks of data. Dragged out bits and compared them in a hex editor. In the other 'make your own OS thread' the idea might come in handy if you had strict rules on compiling and structure of binaries. Basically though, you're talking about restricting libraries people can use to program with. Like Visual basic. VB binaries are sort of like a binary script and the VB dll has the job of doing the actual work. You can have a really small program with a large set of dlls if they can do everything you would ever want to do. I have 1 gig of files in my system32 folder at the moment. If your operating system started out with all the dlls that were allowed in the operating system you could restrict the binary size.
Raavin
Hello,
I'm not much into computer science but like to remind you of something. As you know, there are different versions of MPEG compression scheme. MPEG-1 for data rates about 1.5 Mbps (T1 links for example), MPEG-2 used in VCD and DVD (higher quality at data rates around 5 Mbps, also used in medical imaging), MPEG-3 (MPEG-1, layer 3) only on audio channel in MP3, MPEG-4 in web video. There is an underway vesion of MPEG, namely MPEG-7 or MCDI (Media Content Description Interface), that does exactly what you intend of "understanding" text but does that on images. It uses feature extraction and other machine vision methods to get the "real" things out of motion picture's frames, eg basic shapes and perhaps more complex objects. And instead of recording pixel and motion vectors records the shapes whose description needs much less space.
Raavin.
I see your point.
But i don't see what you are doing with 1 gig of DLLs !
Manuel_Silvio.
So, basicially what this kind of MPEG does is that it changes each frame into (what is so called) Paths, then saved the paths instead of the saving the data pixel by pixel ...
But you know, when you have a frame of a metal square, you always find odd pixels somewhere, that will not come in the whole context.
So if this algorathim tries to actually save those odd pixels as paths, you will end up with a bigger disk space.
Therefore i assume that this compression will not show a movie 100% like the original.
And after all, MPEG is not looseless, right ? (we are talking about looseless compression here !)
Hi there,
You're right STAii; all MPEG standards are lossy algorithms. I think human brain also uses lossy ways to describe its input. Human beings never remember the one-to-one presentation of what they've seen before; they remember pragmatically emphasized details along with their judgement of the picture they've seen. From that I think it is obvious that MPEG is more similar to what human brain does than RLE.
Besides, MPEG-7, I think, goes much further than describing shape vectors. Considering its official name, MCDI, it should be able to describe the frame as a gathering of "objects". These objects can even be defined in a header and then re-used all over the motion picture, so they can be much more complex than basic paths. They may include for example the description unique to a specific computer case that happens to recur over all or many of the frames.
It is obvious that no compression algorithm is perfect. RLE and other lossless algorithms fail when there is low redundancy as with EXE files. MPEG and other lossy algorithms fail when high detail is required. Every algorithm has its drawbacks including the algorithm that our brain uses for pattern matching and object recognition. The erroneous nature of our brain can be simply observed in optical illusions or where individuals mismatch some object with another as long as they're held back from gaining extra information to be fed into the brain.
Aside from human brain, other living processors are known to "unfairly" emphasize certain details that are most important to the survival of their owners and to "selectively" ignore many features of the input signals that are considered "useless" to them.
A possibly efficient compression algorithm can be one that recognizes this selective ignorance and takes advantage of it to cut down the size of what has to be presented to a human brain. DCT algorithm used in JPEG and MPEG is one such example that relies on human eye's indifference to eliminating parts of color gradients.
However, there's a fatal problem with using such schemes for information prepared for computer processing. Our current computers are all linear and clocked. They're finite-state machines that occupy a certain state in each time slot. While human brain is a non-linear parallel processor which isn't bound to occupying a certain state of finite number of states at every given time. This means that you can feed a human brain with ambiguous information and expect something while a computer will stop working at the sight of any ambiguity. Consequently, using lossy algorithms with computers leads nowhere. On the other hand, lossless algorithms will fail because critical information ready for being processed always have very low redundancy, eg in an EXE file.
Oh! I forgot something.
All vector image formats are examples of what you intend with "understanding", ignoring the fact that the user herself/himself gives the understanding to her/his computer through CAD or other applications. DXF, for example, contains a set of pre-defined tokens that describe the shapes. Just like our own brains that describe a monitor as "grey 17" rounded glowing box".
Such tokens are present in raster formats as well. A palette header in a 256 color BMP defines a set of tokens to aviod repeating the same 3 byte RGB values all over the file, it uses the 1 byte palette index instead. Saving a BMP is a totally automated process and the computer, in a sense, understands the image colors and constructs the palette header out of this understanding.
15K
