UK taking physics and looking to study aero eng.
  • Thread starter Thread starter Saoist
    Physics Study Uk
The discussion focuses on the dynamics of supersonic flow interacting with a normal shock wave, specifically the cause-and-effect relationship between shock formation and flow deceleration. It is established that a shock wave forms due to pressure waves created by the interaction of supersonic, sonic, and subsonic regions, leading to a large wavefront. The consensus is that the flow slows down as a result of the shock, rather than the shock itself causing the flow to decelerate. The discussion emphasizes the importance of understanding the unsteady process involved when a solid obstacle is introduced into a supersonic stream.
  • Understanding of fluid dynamics principles
  • Familiarity with shock wave theory
  • Knowledge of supersonic and subsonic flow characteristics
  • Basic grasp of Reynolds number and its implications
  • Study the mechanics of normal shock waves in compressible flow
  • Explore the concept of pressure waves and their interactions in fluid dynamics
  • Learn about the effects of obstacles on supersonic flow behavior
  • Investigate the implications of Reynolds number on shock thickness and flow characteristics
A-level physics students, aspiring aerospace engineers, and anyone interested in the principles of fluid dynamics and shock wave interactions in supersonic flows.
Saoist
hello all, I'm new here...an A-level student in the UK taking physics and looking to study aero eng. that's my profile atm.
to topic...obviously when a supersonic flow travels through a normal shock it reduces to subsonic, but which is the cause and which is the effect? apparently the shock forms due to combined pressure waves (from constructive interference from supersonic, sonic, and subsonic regions) forming a large wavefront.
so from that, you could argue that the flow slows down and the shock forms as a result of that. rather than the shock slowing down the flow.
i may be arguing semantics here. or i might be wrong.
Welcome to PF.
In order to look for the cause and the effect, you may as well to imagine an unsteady process. Imagine there is an stream of supersonic flow everywhere. Imagine you instantaneously put an obstacle (such as an airplane nose) in the stream. Fluid particles traveling downstream will find suddenly a solid surface, crashing into it and causing a rising in local pressure. This pressure wave will try to travel upstream, but it is impossible because its proper wave speed is smaller than the convective fluid velocity. Once the steady state is reached against, in each time you will find a zone of crowded of particles behind the wave, which makes the downstream traveling particles to crash into this "traffic jam" and become slowered down.
So the logical secquence is:
I) the shock is formed by means of a solid surface submerged in a supersonic stream
II) the shock and the great density behind it slows down the fluid once it has passed trough the shock, which by the way has a thickness of the order of the inverse of the Reynolds number.
10K
  • · Replies 102 ·
11K
