What Are the Only Regular Figures That Fill the Plane?
  • Context: Graduate
  • Thread starter Thread starter mprm86
    Regular
The only regular figures that can fill the plane are the triangle, square, and hexagon. This conclusion is derived from the equation k(n-2) = 2n, where k represents the number of polygons that can meet at a point. The analysis shows that n must be greater than 2, and only n values of 3, 4, and 6 satisfy the conditions for tessellation. Other regular n-gons do not meet the criteria for filling the plane.
  • Understanding of regular polygons and their properties
  • Familiarity with algebraic equations and inequalities
  • Knowledge of geometric concepts related to tessellation
  • Basic understanding of angles in polygons
  • Explore the properties of regular polygons in geometry
  • Study tessellation techniques in advanced geometry
  • Learn about the relationship between angles and polygonal shapes
  • Investigate other geometric figures that can fill the plane
Mathematicians, geometry enthusiasts, educators teaching polygon properties, and students studying tessellation and geometric proofs.
mprm86
Show that the only regular figures that fills the plane are the triangle, the square and the hexagon.
Mathematics news on Phys.org
This can be done with algebra after the problem has been restated.
Note that the angle of a corner of a regular n-gon equals (n-2).Pi/n.
To fit the plane, k copies of a regular n-gon must be able to touch with their corners and therefore k angles should make up for a total arc of 2.Pi.
So, k should be chosen such that
k(n-2)Pi/n = 2Pi eq.
k(n-2) = 2n (*) eq.
k = 2n/(n-2).
So, we must choose n such that n-2 | 2n.
This looks already as if there are only few possibities. First note that n must be larger than 2. (Otherwise we don't even have a polygon).
n=3 gives 1|6 which is true, and k = 6/1 = 6
n=4 gives 2|8 which is true, and k = 8/2 = 4
n=5 gives 3|10 which is NOT true
n=6 gives 4|12 which is true, and k=12/4 = 3
How does it go on?
Well, the next quotient will be smaller than 3, so it must be 2, but then this would mean that just two corners n-gon fill an arc of 2Pi and this corner should be Pi, but this does not happen for a finite n.
Therefore, there are no other regular n-gons that tesselate the plane.
You can also look at solving the same equation (*) for n, we get:
n = 2k/(k-2)
So k should satisfy k-2 | 2k
So either
(i) k-2 = 1 or
(ii) k-2 = 2 or
(iii) k-2 is odd and k-2|k
(iv) k-2 is even and (k-2)/2 | k
Ad (i) k=3 and n=6
Ad (ii) k=4 and n=4
Ad (iii) k=2i+1 and 2i-1 | 2i+1. It is clear that if i>1 then (2i+1)/(2i-1) < 2, so this leaves no solutions
Ad (iv) k=2i and (i-1)|2i eq. i=2 OR i=3 only. i=2 gives k=4 and we had this already. i=3 gives k=6 and n=3.
This approach gives the same solutions.
QED
Thanks a lot.
11K
