How to Calculate Radioactive Decay with Half-Life Formula
  • Context: Undergrad
  • Thread starter Thread starter YTech9
The discussion revolves around solving problems related to the half-life formula in radioactive decay and analyzing a mathematical function. Participants are addressing a homework problem that involves determining properties of a function and applying the concept of radioactive decay.
  • Homework-related
  • One participant requests help with multiple parts of a homework problem involving a function G(t) and its properties, including domain, range, intercepts, and asymptotes.
  • Another participant suggests thinking about the general form of the function and the implications of shifting, as well as the characteristics of the domain and range.
  • There is a mention of using principles regarding the relationship between the domain and range of a function and its inverse.
  • One participant expresses difficulty in finding the inverse of G(t) and formulating the radioactive decay function.
  • Another participant provides a proposed vertical intercept and questions the horizontal intercept of G(t).
  • Clarifications are made regarding the vertical and horizontal intercepts, with emphasis on verifying claims made by others.
  • Discussion includes the need to consider limits to determine horizontal asymptotes, with some participants suggesting alternative approaches based on their knowledge level.
Participants express varying levels of understanding and provide differing interpretations of the function's properties, leading to some disagreement on specific values and characteristics. The discussion remains unresolved regarding the exact properties of G(t) and its inverse.
Some participants highlight the importance of verifying claims and understanding the implications of mathematical definitions, indicating that assumptions may be missing or unclear. There is also a suggestion that the discussion may be influenced by different levels of mathematical knowledge among participants.
This discussion may be useful for students working on homework related to functions, inverse functions, and applications of the half-life formula in radioactive decay.
YTech9
Hey Everyone. I'm at my wits end on these problems, and was hoping for some help. Thanks for any input given.
1)Given G(t)=(1.35)^t+7
A)Describe the domain, range, intercept(s) and asymptotes of G(t).
B)Write a formula for the inverse function.
C)Describe the domain, range, intercept(s) and asymptotes of G^-1(t).
D)Use a table to verify that you computed G^-1(t) correctly.
E) Sketch both functions on the same set of axes.
2)Radioactive iodine is a byproduct of a certain type of nuclear reaction. Its half life is 60days. Suppose that an accident occurs and 45pounds of radioactive iodine is released into the environment. The amount of radioactive iodine decays according to the model: f(t)=ab^t.
A)Write a formula for f(t).
B)By what percent is the amount of radioactive iodine decreasing each day?
C)Calculate and interpret the following quantities. Explain why the values are not equal.
f(4)-f(0)/4
f(7)-f(3)/4
D)How long will it take until 80% of the released amount has decayed?
rather than complete the two four part homework problems for you, think of what you already know about the function. What is the general form for the function. what shifting is ocurring. how does this affect the overall function.
for domain this of what values for t won't yield a result.
For Range consider what values for G(t) cannot come from the equation (hint:can a positive raised to any power be negative?)
Intercepts consider when t is 0 and if/when G(t) is 0.
surely there are examples in the text like this, aren't there?
for c, you can use a general principle that the domain and range of f are the range and domain of f-1.
I'm having trouble figuring out the inverse of G(t)=(1.35)^t+7.
Also having trouble with putting problem 2A) into a formula.
Domain: all, range: all, no vertical asymptote, horizontal ass at y = 7. g^-1(x) = log(t/7)/log(1.35)
if the range is all, then for what input is the output 7?
So for the formula G(t)=(1.35)^t+7
Is the vert. intercept: (0,1.35)
No horizontal intercept?
by the way, especially in light of the fact that at least one person here has given you wrong information, be sure to catch an explanation and/or proof of any claim made before you believe it.
the vertical intercept is (0,y) and the horizontal intercept is (x,0).
if you let t=0, what do you get? ie, what is G(0)? it's not 1.35.
if you let G(t)=0 what do you get for t? ie if =01.35^t+7, what is t? what you get, if anything (hint), is the horizontal intercept.
to find horizontal ass you need to take the lim of the function as x approaches infinity.
or if you're in pre-calc, as the title of the thread implies, and a pre-calc class that doesn't use limits yet, then you could start with the statement given without proof that y=0 is a HA for the graph of G(t)=a^t, 0<a, 1!=a, and argue that your G shifts that HA in a certain way. by the way, this is what i'd do even if i knew about limits.
  • · Replies 20 ·
