Why Am I Getting Strange Results Measuring Sphere Densities?
  • Thread starter Thread starter rawr101
    Physics Spheres
The discussion revolves around measuring the density of spheres using water displacement in a graduated cylinder. The original poster is experiencing unexpected results and is seeking clarification on their methodology and calculations.
  • The original poster describes their process of measuring the mass and volume of water before and after dropping the spheres. They question the appropriateness of using a formula for linear mass density and seek confirmation on calculating density from mass and volume.
Participants are actively engaging with the original poster's questions, providing insights into the nature of water displacement and clarifying the distinction between mass and volume. Some guidance has been offered regarding unit conversions and the correct formula for density, though no consensus has been reached on the specific issues with the original poster's data.
The original poster mentions uncertainties in their measurements and expresses a lack of experience, indicating that this is their first physics class.
rawr101
My question is regarding finding volume and densities of spheres. I'm getting strange results, so I thought I'd find out where my methods are incorrect.
I am using a graduated cylinder to drop the spheres into with water inside. I measured the initial volume of the water before I dropped the sphere in. Then I measured it after. I now have the mass, the initial volume (ml) of water, and the final volume of water (along with the uncertainties, using hi-low method :biggrin: ).
Should I use the formula: Linear Mass Density = Mass/Liter?
Thanks for helping.
When you say that you now have the mass, do you mean they gave it to you already or you calculated it from the data? If you say you calculated it from the data, I see what your problem is right away. The sphere does not displace an equal mass of water, but an equal volume. If you dropped a metal ball in that wieghed one gram, and another ball of the same size made of a material so dense it wieghed 1 kilogram, they would both displace the same volume of water since the beaker is equally filled in both cases. It is when objects float that they displace an equal mass of water. There is a minor technical problem with the formula you are using and that is that you are not trying to find a linear mass density, just a density. A linear mass density is something you would measure on a rope or chain and say that it wieghs so many kilograms per meter. But that's just a technical point. If you divide the mass by the volume, you will get the density. The only other problem that comes to mind is to make sure your units are right. What is wrong with the data exactly?
The goal for me is to find the densities. I weighed the metal spheres first and then recorded the initial water volume. I dropped the sphere in and measured the current water level. I'm just curious whether the equation, Linear Mass Density = Mass/Liter, will give me the correct densities I am looking for. Or would this work:
Volume Water Displaced = Final Volume - Initial Volume
volume water displaced = volume
then density = mass/volume
Sorry for these very beginner questions, this is my first physics class :confused: .
Thanks again.
yes, this will give you the density, just rememner that you need to find density in grams per cm^3 or kg per m^3. You need to make sure you convert from volume of water to the metric system. 1000L = 1m^3.
Regards,
Nenad
  • · Replies 16 ·
  • · Replies 97 ·
