Torque on a current-carrying loop
  • Thread starter Thread starter gnome
    Loop Torque
The discussion centers on calculating the torque exerted on a current-carrying equilateral triangular loop in a uniform magnetic field. The initial calculation of torque, T = 2BIx², is incorrect due to the omission of the sine factor in the force equation. The correct torque formula incorporates the cross product of the current element and the magnetic field, resulting in T = IBx²√3. The error was identified by recognizing the need to account for the angle between the current element and the magnetic field.
  • Understanding of torque in magnetic fields
  • Familiarity with the right-hand rule for cross products
  • Knowledge of equilateral triangle geometry
  • Basic principles of electromagnetism, specifically Lorentz force
  • Study the application of the right-hand rule in electromagnetism
  • Learn about the cross product in vector calculus
  • Explore torque calculations for different geometric shapes in magnetic fields
  • Investigate the implications of angle factors in force calculations
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and torque calculations in magnetic fields.
gnome
When a current carrying loop is placed in a uniform magnetic field and the normal to the plane of the loop is ⊥ to the direction of the field (iow the plane of the loop is parallel to the direction of the field), at that moment the torque (about any axis) exerted on the loop is supposed to be
T = IAB
where I is the current, A is the area of the loop, and B is the field.
So, I want to try this out on an equilateral triangular loop with base = 2x, height = x√3, and hypotenuse = 2x.
I'll put my axis of rotation along a vertical line from the apex to the center of the base. This way, the torque on half of the base is clockwise & on the other half counterclockwise, so the base can be ignored in the calculations. By symmetry, the torque contributions of the other two legs are equal, so we can just calculate one of them & then double it. So, now I'm looking at half of the original equilateral triangle: a 30-60-90 triangle, with the axis of rotation along the vertical (long) leg. The measurement along this axis is h = x√3. The measurement along the base is just x.
The magnetic force is exerted along the hypotenuse, L = 2x.
The force exerted on each little piece dL is:
F = BIdL
but
L = (2/√3)h; therefore
dL = (2/√3)dh; so
F = (2/√3)BIdh
The distance from each dL to the axis:
d = (1/√3)h
Therefore the torque contribution from each dL should be
dT = Fd
dT = (2/√3)BIdh*(1/√3)h
dT = (2/3)BIhdh
So the total torque on this half of the triangle is
T = (2/3)BI∫0x√3 hdh
T = (2/3)BI[h2/2]|0x√3
T = (2/3)BI*(3x2/2)
T = BIx2
The torque on the entire equilateral triangle should be double this, or
T = 2BIx2
But this is wrong. The formula says that the torque should be
T = IAB
For an equilateral triangle with side = 2x, A = x2√3
T = IBx2√3
Where did I go wrong?
F = BIdL
The force is given by F = Idl X B, where "dl X B" is the cross product of the vectors dl and B. Since they are not perpendicular, you must include a factor of sin 60. Include that missing factor and your answer is perfect.
Thanks, Doc. I forgot that now I'm dealing with the L vector instead of just the orthogonal to the plane of the loop.
9K
