Thread Closed
Mirror
Share Thread Thread Tools
Aug25-05, 01:49 PM   #1
Recognitions:
Gold Membership Gold Member
Mirror
If a mirror reverses left to right, why doesn't it reverse top to bottom?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug25-05, 04:55 PM   #2
Dunno if this is even worth whiting, but..
It doesn't reverse left and right in the first place. Everything that comes in, left, right, top and bottom goes back out the same place it came. However, if an object is mostly symetrical in two directions (such as humans, for instance) one tends to feel that the projection ought to be a transposed object. Transposing a human by turning it around a half turn left-right wise would sort of fit the projection, but it's local left-right would be reversed. Up/down would, of course, work similarly with a sideways human (or other object symetrical in up/down but not in left/right) - if you tilt yourself pi/2 the mirror won't magiacally reverse you chin to brow but rather reverse you in the "up/down" gravitaionally speaking from your (rather primitive) point of view.
Aug25-05, 05:20 PM   #3
Recognitions:
Very good LarrrSDonald.
Here is more insight, but don't read it unless you want to know the answer.
It's a trick question. As LarrrSDonald said a mirror does not reverse left to right. It actually reverses front to back. That is to say, it reverses across the plane of the mirror. In doing so it reverses handedness and this enhances the suggestion that it reverses left to right. If you place two mirrors at right angles and look at the line of intersection you will see an image that is reversed twice and so handedness is restored. You will finally see yourself as others do.
Thread Closed
Thread Tools
Similar Threads for: Mirror
Thread Forum Replies
Mirror Problem Introductory Physics Homework 1
Mirror Introductory Physics Homework 4
Mirror Introductory Physics Homework 2
mirror General Physics 4
Black and White Mirror / Narrow Band Mirror General Physics 2
