Complete Number Pattern: 400,000; 300,000; 199,800;
  • Context: High School
  • Thread starter Thread starter akl95
    Patterns
The discussion centers on completing a number pattern: 700,500; 600,200; 499,900; __________; ___________; _____________. The approach involves calculating the differences between consecutive numbers to identify a linear relationship, which is confirmed as an arithmetic series with a common difference of -100,300. The method suggests using a triangular construction for clarity and emphasizes the importance of exploring ratios if the initial method does not yield results.
  • Understanding of arithmetic series and common differences
  • Familiarity with basic algebraic concepts
  • Ability to visualize numerical patterns using triangular methods
  • Knowledge of linear and quadratic relationships in sequences
  • Study arithmetic series and their properties
  • Learn about triangular numbers and their applications in pattern recognition
  • Explore quadratic sequences and their characteristics
  • Investigate ratio analysis in numerical patterns
Mathematicians, educators, students, and anyone interested in number theory and pattern recognition.
akl95
I have a number pattern I need help with... can someone complete the pattern and explain the process:
Pattern explain:________________________________________________________ _______________________________________________________________
Mathematics news on Phys.org
Everybody looks for patterns in different ways, depending on how their brain works. For me, I always like to start with the simplist strategies and work up from there. So first start out by finding the difference between each set of numbers, you can easily set up a construction of doing this in a triangle method, which I will attempt to demonstrate on a computer, but is easier to do on paper:
[tex] \begin{multline*}<br /> Number 1 \\<br /> (Number 2 - Number1) \\<br /> \end{multline*}[/tex]
[tex] \begin{multline*}<br /> Number 2 \\<br /> (Number 3 - Number2) \\<br /> \end{multline*}[/tex]
[tex] \begin{multline*}<br /> Number 3<br /> \end{multline*}[/tex]
You can then form a new line by doing the same iterative process down the next group of numbers.
The formula then follows that in the first line that you made, there is a linear relation between the variables. (t) The second line corresponds to a (t^2) quadratic relation etc.
If this doesn't work, start looking at ratios and the like looking for different relationships, but I have a feeling that in this case, it will work well.
~Lyuokdea
This looks like a simple arithmetic series with the common difference = -100,300.
  • · Replies 31 ·
  • · Replies 23 ·
  • · Replies 23 ·
