| Thread Closed |
commutator of L and H |
Share Thread | Thread Tools |
| Nov9-03, 11:03 PM | #1 |
I'm trying to demonstrate that angular momentum and the Hamiltonian commute provided that V is a function of radius r only. Using L = Lx + Ly + Lz components, the definition of Lx = yPz - zPy, etc, the commutator definition and the fact that H = p^2/2m + V. I can reduce [Lx,H] to the following:
[Lx,H] = [yPz,V] - [ZPy,V] and by expanding using and the relation [AB,C] = A[B,C] + [A,C]B and the Pz = hbar/i * d/dz, etc. get [Lx,H] = hbar/i * ( yf dV/dz - zf dV/y) where f is a test function. I have not used the fact that V is a function of r only and I can't take this any further. I know that ( yf dV/dz - zf dV/y) must equal zero but have no idea how to prove it. Please help with a suggestion. (I believe that H commutes with each component Lx, Ly and Lz and not just L so I don't think the terms above will cancel with terms from [Ly,H] and [Lz,H].) |
| Nov10-03, 03:00 AM | #2 |
You should change to a coordinate system with r and two angles. That is , to spherical coordinates. You will have to work out what d/dx is in these coordinates and so on. A lot of writing but that is physics. Don't forget to fill in the spherical coordinates for x, y and z as well.
| Nov10-03, 08:38 PM | #3 |
The book sometimes makes problems hard but it would have a whole section done in rectangular coordinates and then give a problem that must be done spherical coordinates. That's in the next section! Any other suggestions? |
| Nov11-03, 02:15 AM | #4 |
Hmmm...that would be a bit strange indeed. However, if you have a spherical symmetric potential it would be easiest to use spherical coordinates. What book are you using? In my QM classes we used Griffiths and I can remember that sometimes he gave a sort of sneak preview....You can also write d/dx=d/dr*dr/dx and same for d/dy and d/dz. You can write out dr/dx=x*(x^2+y^2+z+2)^3/2....I think that will work (just gave it a quick glance).
Good luck |
| Nov11-03, 05:49 PM | #5 |
Thanks for the suggestion! Worked great.
dr/dx = x *(x^2+y^2+z^2)^(-1/2), etc. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: commutator of L and H
| Commutator | Advanced Physics Homework | 1 | ||
| commutator help | Advanced Physics Homework | 4 | ||
| The commutator [L,p] | Advanced Physics Homework | 7 | ||
| Commutator maths | Advanced Physics Homework | 8 | ||
| Commutator Confusion | Linear & Abstract Algebra | 3 | ||
