The size of the sun using pinhole imagery
  • Context: High School
  • Thread starter Thread starter taylorb
    Sun The sun
The discussion revolves around the use of pinhole imagery to determine the size of the sun and the factors affecting the projection of its image. Participants explore the relationship between the intensity of sunlight, the dimensions of the pinhole, and the distance from the pinhole to the imaging plane.
  • Experimental/applied
  • One participant questions whether the intensity of sunlight affects the quality of the image produced by the pinhole, noting difficulties in obtaining a clear projection.
  • Another participant requests clarification on the specifics of the setup, including the size of the hole and the distance to the imaging plane.
  • A participant describes their experimental setup, detailing the construction of the pinhole and the distances used, while noting the challenges in measuring the projected image size.
  • One participant provides a geometric relationship to estimate the spot size, suggesting that the distance and angular diameter of the sun must be considered to achieve a good image.
  • Another participant suggests using smoked glass to test the effect of light intensity on the spot size as part of the experimental approach.
Participants express various viewpoints on the factors influencing the image quality, and no consensus is reached regarding the impact of sunlight intensity or the effectiveness of the pinhole setup.
Participants have not fully resolved the assumptions regarding the geometry involved in the projection and the specific conditions under which the experiments are conducted.
taylorb
Does intensity of the sun affect this? I keep trying to do it, and when you have a square shape you should still see an image of the sun.. right? Well it is not working! I live in a place with VERY intense sun and no clouds... could this be the problem?
Any help!? Thanks so much...
Science news on Phys.org
What, exactly, are you seeing? How big is the hole? How far apart are the hole and your imaging plane?
OK... what I did was cut a square in the center of a piece of stiff construction paper. Then I covered the square with a piece of tin foil. Then I punctured the middle of the piece of tin foil with a sewing needle (very small). When I went outside I started out with the pinhole about a foot away from the piece of white paper on the ground that I was trying to project the image onto. I got a tiny dot... slightly bigger than the pinhole itself... very difficult to measure. So I moved the pinhole further away and closer to try and make the image bigger with very little change. So I have put it very close and about four and a half feet away. We are also meant to try it with a small square and it is still meant to show an image of the sun, but when I make a small square that is exactly what is projected on the piece of white paper!
Thanks!
Taylor,
As a rough guide, basic geometry gives the spot size as
[tex]y = D_H + L \theta[/tex]
where [itex]D_H[/itex] is the diameter of the hole, [itex]L[/itex] is the distance between the hole and the image plane and [itex]\theta[/itex] is the angular diameter of the Sun (in radians). In order to get a "good" image of the Sun, you will need to arrange for [itex]L \theta[/itex] to be larger than [itex]D_H[/itex].
Good luck!
experimentally speaking, you may put some smoked glass otside the pinhole to check if light intensity affects the spot size. that is one of the way to do physics.
  • · Replies 125 ·
  • · Replies 49 ·
