Electric energy of a dielectric sphere
The discussion centers on calculating the total electric energy of a dielectric sphere placed in a uniform electric field generated by a parallel-plate capacitor. The sphere is characterized by a relative dielectric constant "epsilon(r)" and radius "r". The participants emphasize the importance of understanding the electric field within the sphere and the role of surface charge density in determining electric potential energy. The application of Maxwell's equations is also highlighted as essential for deriving charge density in this context.
  • Understanding of electric fields in dielectrics
  • Familiarity with Maxwell's equations
  • Knowledge of electric potential energy calculations
  • Concept of surface charge density
  • Study the derivation of electric potential energy in dielectrics
  • Learn about the application of Maxwell's equations in electrostatics
  • Research the concept of surface charge density and its implications
  • Explore the relationship between electric fields and dielectric materials
Students and professionals in physics, electrical engineering, and materials science who are studying electrostatics and the behavior of dielectrics in electric fields.
hhh79bigo
Electric energy of a dielectric sphere!
Hi there, I have attempted a question, I was just seeing if some one can go over it and check if it is ok!
Q. The Electric field E inside a dielectric sphere placed between the plates of a large parallel-plate capacitor is uniform. Given that the sphere has a relative dielectric constant "epsilon(r)" and radius r, find an expression for the total electric energy of the sphere.
My working out is as attached to this message:
If there is more that can be done then can you help aswell!
Thanks a lot
It looks like you've answered the question as if the charge on the plates is known. I would have presumed, from the wording of the question, that the Electric Field is known. This would make the Electric field energy within the sphere obvious (epsilon E^2 Volume), but the total Electric (potential) Energy *of* the sphere would not be trivial to calculate. In my view, the surface charges are what actually belong to the sphere; the external E-field belongs more to the environment than to the sphere.
I would've found the surface charge density first, then the Electric PE due to that surface charge density by surface integration. That way you end up *showing* the utility of the new Energy density approach (which I suppose is the "new topic").
of course, I've been known to misinterpret questions before ... .
I don't fully understand, do i have to use maxwells equations to find the charge density, and if so how does this apply to a dielectric between 2 capacitor plates. I thought that the E field would be E(0)/EPSILON(r) where E(0) is the Electric field of the capacitors without the dielectric.
using DIV(E)=Charge desnsity/epsilon(0) I think I'm right in saying this is one of maxwells equations.
Hope you can help clarify this for me. Thanks a lot for you help
hhh79bigo
