Proof: One more irrationality proof
  • Thread starter Thread starter mattmns
    Proof
The discussion revolves around the proof of a statement regarding irrational numbers and their powers, specifically whether there exist irrational numbers x and y such that x^y is rational. Participants explore the implications of the statement and consider counterexamples.
  • Participants discuss the nature of the statement and its negation, questioning how to formulate implications correctly. They also consider the existence of counterexamples and the reasoning behind finding them.
The conversation is active, with participants sharing insights and questioning assumptions. Some have suggested potential counterexamples, while others are clarifying the implications of the original statement. There is no explicit consensus, but productive lines of inquiry are being explored.
Participants are navigating the complexities of quantifiers and implications in the context of irrational numbers, with some expressing uncertainty about the definitions and the nature of the proof required.
mattmns
Proof: One more irrationality proof :)
Ok, for this one I cannot even start the proof because I do not even know what I am trying to prove :mad:
The question states:
Prove of give a counterexample: there do not exist irrational numbers x and y such that x^y is rational.
Ok, let's knock out the counterexample, because I think that there is definitely not one. And now it is a proof, and the statement is an implication. But which way is the implication is what I cannot figure out.
Is it: If x and y are irrational, then x^y is irrational? Or, If x and y are rational, then x^y is rational?
Danke!
The statement is not true. Think about logs.
Ohh, well that makes it so that I do not even have to prove it. Sweet! I will mess around with that. Thanks.
However, what if it were ture. Then how would I write the implication so that I could prove it?
That says:
It is false that there exists irrational numbers x and y such that x^y is rational.
right? How does negation propagate through quantifiers?
P.S. it's a simple matter to have figured out how to find the counterexample yourself. You were probably limiting your options!
Note that the counterexample consists of three parts:
An irrational number x
An irrational nubmer y
A rational number x^y
You probably tricked yourself into thinking you need to guess irrational x and y, hoping to get a rational x^y.
It's far easier to guess a rational x^y and an irrational x, and hope for an irrational y. :smile:
Then it would be: It is true that for all irrational numbers x and y that x^y is irrational. (Which is going to be false because there is a counter example.
So then the implication would be: If x and y are irrational, then x^y is irrational. Correct? Thanks.
So when I am looking for a counterexample I should think about finding a counterexample of the contrapositive too, or break it into parts as you have.
So there are a infinite counterexamples. When you say it the other way around it is easy :smile:
[tex]\pi^{log_{\pi}42} = 42[/tex]
Whenever I get a chance to make things whatever I want, I am supposed to make them cool numbers right? :smile:
Thanks!
you proved thatlog of pi in base 42 is irrational did you? seems like oyu're assuming the answer.
anyway, here is *the* counter example.
conjsider sqrt(2), raise it to the power sqrt(2) what do you get? rational or irrational, if it's rational you've got a counter example, and even if not what can you do now to get a coutner example?
  • · Replies 85 ·
9K
