Originally Posted by Twukwuw
Andrew,
The intermolecular forces between atoms or molecules can give the atoms or molecules ENOUGH centripetal force,but it never give the CENTRE of MASS centripetal force!
Just imagine there is a box, many particles there (u can imagine there is just 2 particles!) , the vector sum of the intermolecular forces will be ZERO, because every force come in pairs of SAME magnitude but DIFFERENT direction! Tjis is Newton's third law.
My question is...
When the top is spinning, and when its axis of symmetry make an angle>0 with the vertical axis, its centre of mass will make a circular motion with constant angular speed.
In other words, the top is making processional motion.
Now, What produce the centripetal force?
Is it the fiction force between the top's tip and the land?
If so, why is the direction of the fiction pointing that way?
The direction of the fiction should be in opposite direction of the centripetal force!
If the speed of precession is slow, the
friction between the base of the top and the surface it is on supplies the horizontal force to the base which, via mechanical forces that hold the top together, supplies a horizontal component of force to the top's centre of mass. If there was no horizontal friction, the center of mass would remain fixed and the axis would precess around it.
Your question about the direction of the friction force is a good one. There are two competing forces that are countered by the friction force.
1. the horizontal component of the gravitational turning force. The earth's gravity creates a
torque on the centre of mass of the top (the tip of the top being the fulcrum). This is equal to the component of gravitional force perpendicular to the axis of spin multplied by the distance of the centre of mass from the tip. If the tip is to remain fixed, the surface must supply a (static friction) force equal to the horizontal component of this turning force.
2. The horizontal centripetal force on the centre of mass. Torque produces a change in angular
momentum of the top. (
). The
angular momentum must change, which means the direction of the axis must change. Since the tip is fixed, the center of mass must rotate in order for the angular momentum vector to change. As the axis directon changes, the direction of the torque changes, which causes a further and continual change in the angular momentum vector. The continual change in the direction of the axis, with the tip fixed, creates circular motion which requires a horizontal centripetal force on the centre of mass. This must be supplied by the friction at the tip, which acts in the opposite direction to the static friction force in 1.
Keep in mind that for a slowly precessing top, the centripetal force to keep the centre of mass moving in a
circle is not very great.
The best illustration of this centripetal force is with a horizontally spinning gyroscope that has one end fixed to a vertical tight rope. As the gyroscope precesses, the horizontal component of the rope tension must supply the centripetal force for the gyroscope's centre of mass as it moves in a circle. You can see the rope bowing outward to supply this centripetal force.
AM
