How to visualize joint uniform distribution
The joint uniform distribution for random variables X and Y is defined over the region where 0 ≤ x ≤ y ≤ L, with L being a positive constant. When L = 1, the distribution forms a triangular shape above the line y = x within the unit square. The expected values of the squares of X and Y are calculated as E[X^2] = L^2/6 and E[Y^2] = L^2/2, respectively. This triangular prism representation aids in visualizing the distribution's properties.
  • Understanding of joint probability distributions
  • Familiarity with uniform distribution concepts
  • Basic knowledge of integration techniques
  • Concept of expected value in probability theory
  • Explore visualizations of joint uniform distributions using tools like Python's Matplotlib
  • Learn about triangular distributions and their properties
  • Study the derivation of expected values in continuous distributions
  • Investigate the implications of changing the constant L on the distribution shape
Statisticians, data scientists, and students of probability theory seeking to understand joint uniform distributions and their visual representations.
Mad Scientists
Lets say you have X and Y, where the joint density function for X and Y is uniform over the region defined by 0<=x<=y<=L, where L is some positive constant.
The question asks for the expected value of the squares of X and Y.
I am having trouble visualizing what such a distribution would look like. Apparently it is triangular shaped... but I do not see it. Can anyone help?
Thanks in advance...
:confused:
Suppose L = 1. Then the distribution is defined over the triangle above the y = x line in the unit square. The frequency is marked on the Z axis and is constant over the whole triangular area. So, you have a triangular prism; its volume = 1 by definition.
just integrate,
you will get:
[tex]E[X^2]=L^2/6[/tex]
[tex]E[Y^2]=L^2/2[/tex]
