Finding Fourier Coefficient for f(x) = 2δ(x-1) + δ(x-2)
The discussion revolves around finding the Fourier coefficient for the function f(x) = 2δ(x-1) + δ(x-2), specifically focusing on the sine series representation. Participants are exploring the implications of the function's definition and its periodicity in relation to the Fourier series formulas provided.
  • Participants are examining the appropriate limits for integration when calculating the Fourier coefficients, considering the periodic nature of the function and its representation over the specified interval. There is also discussion about the necessity of extending the function to maintain odd symmetry for the sine series.
Some participants have offered insights into the limits of integration and the nature of the Fourier series being sought. There is an acknowledgment of the need to clarify whether the coefficients for sine terms alone are required, and the discussion reflects a productive exploration of these aspects without reaching a definitive conclusion.
Participants note that the function is defined only within the interval [0, 3], which raises questions about how to handle the periodic extension and the implications for the Fourier coefficients. There is also mention of the potential impact of choosing different limits on the resulting coefficients.
Zaare
I'm somewhat confused about how to find this particular Fourier coefficient. Let me explain:
I have these two formulas from the book:
[tex] (1) \qquad f\left(x\right) = \frac{a_0}{2}+\sum_{n=1}^\infty\left[a_n cos\left(n \Omega x\right)+b_n sin\left(n \Omega x \right)\right],<br /> \quad \Omega = \frac{2 \pi}{T}[/tex]
[tex] (2) \qquad b_n = \frac{2}{T} \int_{a}^{a+T} f(x) sin(n \Omega x) dx[/tex]
where [tex]T[/tex] is the period of the function [tex]f(x)[/tex].
And I'm supposed to find the Fourier coeffecient in the following:
[tex] (3) \qquad f(x) = 2 \delta (x-1) + \delta (x-2) = \sum_{n=1}^\infty b_n sin\left(\frac{n \pi x}{3} \right), \quad 0 \leq x \leq 3.[/tex]
Now, if I compare (3) and (1):
[tex] sin\left(\frac{n \pi x}{3} \right) = sin(n \Omega x) \Rightarrow \Omega = \frac{\pi}{3} \Rightarrow T = 6.[/tex]
According to (2), I'm supposed to use 0 and 6 as the limits for the integral. But (3) limits x to between 0 and 3.
So what limits am I supposed to use for the integral, and why?
I'd appreciate any help.
From what I can tell, you are not trying to find the coefficients of the Forier series, but of the sin series. By that I mean you are not trying to find coefficients for the cos terms. Is that correct? If it is, then you must extend the function in an odd way because the sin function is odd. You can only have a sin series if f(-x)=-f(x) because this will be true of each of the terms in the series. So, what you have to do is extent the function to be [itex]f(x)=2 \delta (x-1) + \delta (x-2) - 2 \delta (x+1) - \delta (x+2)[/itex]. What they mean by the bounds is that the series should represent the function on the interval for x between 0 and 3. Since you have not changed the value of the function on this interval, the series you get will represent the function on that interval. Then you extend it again to be periodic. It should repeat every 6 units. Then just compute the coefficients. Of course, this is all wrong if you were supposed to use cos terms too.
so you need
a<=0<=3<=a+6 (since T=6)
thus any a in [-3,0] will work
If f was not zero out side of [0,3] the coefficient would depend upon the choice of a (and thus the periodic extensions would differ) but here they do not.
I think you're correct in your assumption, LeonhardEuler, since the problem is: "Fourier series: Find the coefficient". So I assume they only want the coefficient of the sin terms.
Thank you for the help.
And, lurflurf, thanks for the explanation about the limits.
  • · Replies 21 ·
