Calculating electric field from radiant flux density
The discussion focuses on calculating the amplitude of the electric field (E₀) from the radiant flux density of a laser pulse lasting 10^{-12} seconds with a radiant flux density of 10^{20} W/m². The integral of the instantaneous energy flux density, expressed as E²/(\mu₀c), over the pulse duration is equated to the radiant flux density. The participant suggests simplifying the calculation by eliminating the integral and emphasizes the importance of using the average value of cos², which is 0.5, to derive the correct amplitude of the electric field.
  • Understanding of electromagnetic radiation principles
  • Familiarity with the concepts of radiant flux density and energy flux density
  • Knowledge of integration in the context of physics
  • Basic understanding of units in electromagnetism
  • Study the relationship between radiant flux density and electric field amplitude in electromagnetic waves
  • Learn about the average value of trigonometric functions in the context of wave physics
  • Explore the derivation of energy flux density from electric field equations
  • Investigate the implications of pulse duration on electromagnetic wave behavior
Physicists, electrical engineers, and students studying electromagnetism who are interested in the calculations related to electric fields and radiant flux density in laser applications.
eep
Hi,
The problem is stated as follows:
"A laser provides pulses of EM-radiation in vacuum lasting [itex]10^{-12}[/itex] seconds. If the radiant flux density is [tex]10^{20} <br /> {\frac{W}{m^2}}[/tex], determine the amplitude of the electric field of the beam."
So far, I figure that the period of one wave is [tex]10^{-12}[/tex] seconds. The instantaneous energy flux density is equal to [tex]\frac{E^2}{{\mu_o}c}}[/tex]. So an intergral of the instantaneous energy flux denisty over a period should equal the radiant flux density, no?
[tex]\int_{t=0}^{t=10^{-12}} \frac{E^2}{\mu_oc} dt = 10^{20} \frac{W}{m^2}[/tex]
Now, [tex]E = E_o cos({\omega}t)[/tex] and [tex]{\omega} * 10^{-12} = 2\pi[/tex]. So I should be able to integrate and solve for [tex]E_o[/tex]?
No, the [tex]10^{-12}[/tex] figure gives the duration of the pulse, not the period. I don't think that you need that number to make the calculation. For that matter, an E&M pulse with a period of 1 picosecond wouldn't be a "laser", but instead would be a short wavelength radar. So my guess is that the [tex]10^{-12}[/tex] is included to either confuse you or to make you integrate out to find an average electric field when you compute the wattage.
Admittedly, I did not take undergraduate E&M and I'm a little hazy about units, but your integral looks to me like the thing you're integrating is correct. But my suggestion is that you get rid of the integral and the [tex]dt[/tex]. Other than that, I believe you can now solve for [tex]E_0[/tex], which is the amplitude of the electric field. If you leave the integral in, you will definitely have the wrong units (check em).
By the way, you probably already know that the average value of [tex]\cos^2[/tex] is 0.5, which gets back to why they gave such a large number for the pulse duration (that is, so that the average would be correct).
Carl
