| Thread Closed |
Leaf Spring Design |
Share Thread | Thread Tools |
| Sep5-05, 07:37 AM | #1 |
Leaf Spring Design
Hi guys,
We need help on deciding which type of leaf springs to use for our vibratory feeder. I did some research on the topic which leads me to some questions. 1. We need to know the Flexural Modulus of different materials, like stainless steel 304, 316, and plastics. Is there any free source on the net that provides this kind of information? We have searched on Internet but so far only come up with very limited information. Or is there any simple way to determine the modulus ourselves? 2. We also need to know the maximum stress the spring can withstand, so that we don’t break the spring by putting the feeder under long operation. Again, if there isn’t an information table, can we work that out by experiment? Thank you for any help. Alex |
| Sep9-05, 10:09 AM | #2 |
Flexural Moduli for plastics are much easier to find that for metals
If you have access to a UTM, you can do flexural tests yourself, perhaps with the help of the UTM operator. Also, if it's only rough numbers you want, and the flexural modulus is hard to come by, you might be able to make do with the linear elastic (Young's) modulus instead. This is usually pretty close to the and often about 5-10% lower. http://www.matweb.com/search/GetProperty.asp Matweb also lists flexural yield stresses for many plastics and some metals. But if you are doing a test to determine the modulus, going a little further to find the yield/breaking stress will not take a whole bunch more of effort. |
| Sep9-05, 10:12 AM | #3 |
I hope this (and thousands more) is what you see when you click the link :
If not, go to matweb.com, and use the property search feature. Among properties, select flexural modulus from the first property list and say, elastic modulus from the second and yield stress from the third (or whatever else you like). Select your min/max range according to your design requirements, or if you have none, make the range 0.01 to 200 GPa (or something safe like that). |
| Sep11-05, 02:38 AM | #4 |
Leaf Spring Design
I'm uncomfortable with that question. You are asking for 'book' answers to a simple question you should have been able to solve without any help. What is the real nature of your problem? Is it an application problem? If so, please elaborate. I've had many of those, as have many other engineers. It's OK, I won't compromise any trade secrets... so long as you help me solve my bearing problem...
welcome to pf, alex! |
| Sep11-05, 07:01 AM | #5 |
Hi Alex, welcome to the board.
- Aluminum = 10,400,000 psi - Berylium Copper = 18,500,000 - Brass or Bronze = 16,000,000 - Copper = 17,500,000 - Nickel Alloy = 30,000,000 - Steel, carbon or alloys = 30,000,000 - Stainless Steel = 27,500,000 |
| Sep12-05, 09:02 AM | #6 |
Admin
Welcome to PF Alex.
Just adding to what the other say, there will be limited information available on the internet, and perhaps it will be rather general. Organizations like ASME, SAE, ASM International, and TMS (all engineering/technical societies) publish Handbooks which give material properties. Or you could go to a site of a vendor who supplies a particular material, e.g. SS316 and or acrylonitrile, and perhaps find properties. |
| Sep13-05, 03:15 AM | #7 |
Again, I need more application details to give an informed opinion. What property is giving/not giving the desired result? And, moreso, what performance parameters are you looking to meet? Application details are everything in engineering. Applied science is the most difficult discipline in all the sciences. Everything pushes the envelope.
| Jun22-09, 08:35 AM | #8 |
Hello Alex I have just seen this very old item and I wondered if you have ever looked into composite springs that have been specially made for vibratory machinery. This is not an AD but if interested I suggest that you check out www.heathcotes.com and others!!!! Most vibrating conveyors and feeders worldwide use composite leafsprings due to their higher Fatigue performance.
| Mar4-10, 07:58 AM | #9 |
Good afternoon,
Can someone help me with leaf spring selection for vibtaroty conveyor? I would like to make a vibratory conveyor (feeder) and I would like to select proper leaf springs for it. First of all, can somebody tell me which material is the best solution for it? I think it should be glass fiber, but what kind of glass fiber should be used (in matweb site I found properties of glass fiber, but there are few tipies of it: A-glass fiber, C-glass fiber, G-glass fiber...and I would like to know which type of fiber glass is the best for it)? Also, can someone tell me who is supplier of springs and send me web-site of manufacturing? Thank you advance |
| Mar4-10, 09:07 AM | #10 |
| Mar6-10, 05:53 AM | #11 |
Hello,
Can anybody give me a piece of information who is vibratory motor supplier (manufacture) in Europe? I found Renolds Ajax Company in USA, but I would like to have the contact of European supplier. |
| Mar8-10, 11:15 AM | #12 |
Electro magnetic drives (Magnet-Schultz). Larger drives are usually either direct hydraulic or pneumatic but there are also a number of manufacturers of out of balance motors such as Vibrotechniques.
| Mar10-10, 11:51 AM | #13 |
Hello again,
I would like to have a small advice from you.I would like to calculate elastificity of leaf springs for my vibratory conveyor and I will do it by elastificity of all system. My question is: is elastificity of all system including mass of all components of system (pan, frame, drive and supporting structure) or this components without mass of supporting structure? Also, how to determinate an elastificity of all system: either sum of elastificity vibratory components (leaf springs and tension springs), by the formula K syst=K leaf springs + K tor.springs or by the formula: 1/K sys = 1/K leaf springs + 1/K tor.springs? Thank you very much advance |
| Mar11-10, 09:43 AM | #14 |
To calculate this you assume that all the structure is inelastic. Ie not elastic! This leaves only the leaf springs to bend as the elastic part of the system.
| Mar12-10, 07:09 AM | #15 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Leaf Spring Design
| Design of Spiral Spring | Mechanical Engineering | 2 | ||
| Parabolic Leaf Springs | Mechanical Engineering | 1 | ||
| Leaf Pigments | Biology, Chemistry & Other Homework | 1 | ||
| a really big stem and leaf plot? | General Math | 9 | ||
| Rutherford's Gold Leaf exp. | Quantum Physics | 6 | ||
