Solving Tension Problem with 3 Cables | Philip
  • Thread starter Thread starter philipc
    Cables Tension
The discussion revolves around a tension problem involving a weight supported by three cables arranged in the X, Z plane. The original poster, Philip, expresses difficulty in solving the problem using a method that has previously worked for simpler configurations, leading to confusion with the number of equations and unknowns involved.
  • Philip initially attempts to use a system of equations to solve for tensions but questions whether there are alternative methods or general principles he might be overlooking. He reflects on the complexity introduced by the lack of symmetry and the challenge of managing multiple unknowns.
Participants have provided insights into the conditions for equilibrium and the necessity of angles for the cables, suggesting that fewer equations may suffice if the angles are known. Philip later indicates a resolution to his issue by recognizing a more straightforward approach that involves fewer unknowns.
Philip mentions that he has the locations of the cable attachment points, which allows him to determine the angles, but initially struggled with the number of equations derived from breaking tensions into components.
philipc
I'm a bit stuck on a tension problem, I have a weight supported by three cables.
I will have to admit, up to this point, I have been cheating on these tension problems. What I have been doing is writing various equations and using my TI-89 to solve the system of equations. This method has been working for me when having only two cables or the three cables being some what symmetric. This problem puts the three cables all on the X, Z plane (judging by the picture) but they have no symmetry beyond that. Using my method I have nine unknowns, so I created to what I believed to be 9 valid equations, but my TI-89 didn't really like that.
I once remember my professor talking about some sort of triangle, so my question, is there a better way to solve this sort of problem. I'm not asking for the problem to be solved, I just need a different approach.
Thanks guys and gals
Philip
To get the needed equations, consider the conditions for equilibrium: The sum of the forces in any direction must be zero; the net torque about any point must be zero.
If you really have 9 equations and 9 unknowns, what's the problem? Solve it, step by step. (To get more targeted advice, show the exact problem and your attempted solution.)
Doc,
I was just wondering if there was a different approach that using 9 equations, some general laws I'm missing out on.
To show the exact problem would be much harder than describing it, it's pretty simple, just imagine a mass hanging from three cables, and there three cables can be attached any where on the x,z plane. Where the mass is attached to the three cables on the negative y axis.
Far as my 9 equations, I'm guessing that I went down a wrong path, giving me incomplete data for the TI-89 to work with.
Setting the three separate x,y,z tensions equal only gives me three equations. What would be the next approach to obtain the next 6 equations?
Thanks
Philip
If you have the angles that the cables make, then all you probably need are three equations. (The tensions are the three unknowns.) If you don't have the angles, then you don't have enough information to solve for the tensions.
I just solved it, thanks
I do have the locations of the points where the cables are attached, so I can make the angles. What I was doing was breaking each tension into 3 parts giving me 9 unknowns. I found a similar problems solved where they only used the three tensions as unknowns and used the sum of each i,j,k vector to make 3 equations. This method was much easier and giving only three unknowns, so it all worked out in the end.
Thanks again
Philip
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 22 ·
