Transfer Functions: Vo = Vi Calculation Help
  • Thread starter Thread starter quick
    Functions
The discussion focuses on the calculation of transfer functions, specifically the output voltage (Vo) in relation to the input voltage (Vi) using the formula H(s) = sL/(sL + R + 1/sc). The user successfully derived the transfer function and confirmed the correctness of their calculations. They also provided an alternative expression for Vo, demonstrating the manipulation of terms to simplify the equation. The importance of careful parenthesis matching in these calculations was emphasized as a key factor in achieving accurate results.
  • Understanding of transfer functions in control systems
  • Familiarity with Laplace transforms and the variable substitution j*omega = s
  • Knowledge of circuit components: resistors (R), inductors (L), and capacitors (C)
  • Ability to manipulate algebraic expressions involving complex numbers
  • Study the derivation of transfer functions in control theory
  • Learn about the implications of pole-zero placement in transfer functions
  • Explore the use of MATLAB for simulating transfer functions
  • Investigate the impact of component values on system stability and response
Electrical engineers, control system designers, and students studying circuit analysis and transfer functions will benefit from this discussion.
quick
http://img66.imageshack.us/img66/9784/prob17zo.jpg
j*omega = s
so for a, i got Vo = Vi * (sL/(sL+R+1/sc))
so H(s) = sL/(sL+R+1/sc) and i multiplied it by s/s to get rid of s in in denominator of the 1/sc term to get s^2*L/(s^2*L+Rs+1/c)
is this correct?
for the second one i got Vo=Vi*(1/sc)/(R*sL/R+sL)+1/sc. i did a similar thing by multiplying by s/s.
any suggestions would be appreciated.
that looks right to me. Only you need to match parenthesis carefully.
[tex]H(s) = \frac{sL}{sL+R+\frac{1}{sC}}[/tex]
[tex]Vo=Vi\frac{\frac{1}{sC}}{\frac{RsL}{R+sL}+\frac{1}{sC}}[/tex]
  • · Replies 40 ·
26K
