Solving Electric Transients in RC Circuits: Time Constant & Voltage Calculations
  • Thread starter Thread starter cunhasb
    Electric
This discussion focuses on solving electric transients in RC circuits, specifically calculating time constants and voltage decay. The first problem involves a time constant of 40 microseconds, where the capacitor discharges from 80 volts to 5 volts, resulting in a time of 40 microseconds using the formula t = RC ln(V/V0). The second problem features a time constant of 0.0001 seconds, with the capacitor discharging from 100 volts to 20 volts, also yielding a time of 0.0001 seconds using the same formula.
  • Understanding of RC circuit theory
  • Familiarity with exponential decay equations
  • Knowledge of the natural logarithm function
  • Basic skills in electrical engineering principles
  • Study the derivation of the voltage decay formula V = V0e^(-t/RC)
  • Explore practical applications of RC circuits in timing and filtering
  • Learn about the impact of different resistor and capacitor values on time constants
  • Investigate transient response in RLC circuits for more complex scenarios
Electrical engineers, physics students, and anyone interested in understanding the behavior of RC circuits during transient states.
cunhasb
I would really appreciate if anyone could help me figure out these problems...
An RC circuit has a time constant of 40 microseconds. If the capacitor is first charged to a voltage of 80 volts and the RC circuit is then closed upon itself, after what time will the capacitor voltage be equal to 5 volts?... and
An RC circuit has a time constant of 0.0001 second. If the capacitor C is charged to 100 volts and, with the battery removed, the capacitor is then allowed to discharge through the resistor, at what time after being connected to the resistor will the voltage be 20 volts? (Assume that, in discharging, the voltage V at any time is equal to V=V(0) e^(-1/RC), where V(0) is the voltage to which C was charged.)
Thank you so much guys...
1. For the first problem, the answer is 40 microseconds. To calculate this, you need to use the formula V = V0e^(-t/RC). This can be rearranged to solve for t (time): t = RC ln(V/V0). Plugging in the given values yields t = 40 μs. 2. For the second problem, the answer is 0.0001 second. To calculate this, you need to use the formula V = V0e^(-t/RC). This can be rearranged to solve for t (time): t = RC ln(V/V0). Plugging in the given values yields t = 0.0001 s.
