What are the tensions in BC and BD?
  • Thread starter Thread starter Uninspired
    Moments Point
The discussion focuses on determining the tensions in cables BC (Tbc) and BD (Tbd) in a static equilibrium scenario involving a 100 kg weight and a 20 kg bar. The moment about point A is established as zero, leading to the equation 0 = (Raf x Wab) + (Rab x Wbe) - (Rab x Tbc) - (Rab x Tbd). The user seeks guidance on calculating the magnitudes of Tbc and Tbd using unit vectors Ebc and Ebd, while ensuring the setup adheres to the principles of vector algebra and static equilibrium.
  • Understanding of static equilibrium principles
  • Familiarity with vector algebra
  • Knowledge of moment calculations in physics
  • Ability to work with unit vectors in three-dimensional space
  • Study the principles of static equilibrium in mechanical systems
  • Learn vector algebra techniques for calculating tensions in structures
  • Explore the use of unit vectors in force decomposition
  • Review examples of moment calculations in engineering mechanics
Students and professionals in engineering, particularly those focusing on structural analysis, mechanics, and physics, will benefit from this discussion.
Uninspired
mass of e is 100 kg
mass of bar is 20 kg and acts at midpoint
sume of moments about point a due to weight of bar and forces on b by bc, bd, and be, are 0, determine tensions in bc and bd
so i continued like this.
The moment about point A from all those forces is 0.
0 = (Raf x Wab) + (Rab x Wbe) -(Rab x Tbc) - (Rab x Tbd)
I can figure out the first two terms of this eq, but i have to find magnitude of the vectors of Tbc and Tbd. But i only have this equation and these two equations:
Tbc= |Tbc|*Ebc where Ebc is a unit vector in BC direction
Tbd= |Tbd|*Ebd where Ebd is a unit vector in the BD direction
Did i set this up incorrectly or how do i proceed?
a picture has been included.
Thanks for your help
Pt A is at the origin
Pt D is (0,5,5)
Pt C is (0,4,-3)
Pt B is (4,3,1)
Pt E is where the 100 kg weight is
AB is the bar where 20 kg acts down the midpoint
any help is APPRECIATED!
bump, anyone?
You know the position vectors of all the points.
Use vector algebra to work out the vectors AB, DB, CD.
Thes structure is in static equilibrium, therefore
[tex]\sum F_i = 0[/tex] [tex]\sum F_j = 0[/tex] [tex]\sum F_k = 0[/tex]
[tex]\mbox{If}\ \bf{AB} = (x_1,y_1,z_1)\ \mbox{then}\ F_{AB} = \lambda(x_1,y_1,z_1)[/tex]
You should be able to use the above two lines to solve the problem.
11K
