Thread Closed
Seebeck Voltages
Share Thread
Sep5-05, 02:15 PM   #1
Seebeck Voltages
I have an issue with converting these to temperatures. I have the equation, voltage is in microvolts, but when I convert, say boiling water at 3600 microvolts to celsius, it gives me something like 90 C. It ought to be close to 95 C, I am in Colorado.
I did it today in excel, and the matlab equation I wrote for it last week gave me the same answer. According to the lab handouts, the error should only be +/- 0.05 C.
Thanks for any help!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep5-05, 03:31 PM   #2
Recognitions:
Let's see what you are doing. Are you actually using a thermocouple? What metals are you using? You could possibly be using the wrong coefficients...
Sep5-05, 06:25 PM   #3
Yes, we are using thermocouples made of Ni-Ch and Ni-Al
Type K thermocouples (given by profs)
Here is the equation
T = 0.0 + 2.508355e-2*v + 7.860106e–8*v^2 + –2.503131e–10*v^3 + 8.315270e–14*v^4 + –1.228034e–17*v^5 + 9.804036e–22*v^6 + –4.413030e–26*v^7 + 1.057734e–30*v^8 + –1.052755e–35*v^9
Again v is in microvolts, and T is in celsius.
Because I am just a few degrees off, I am wondering if the polynomial is right, ie do we have the right thermocouple type.
Sep5-05, 10:45 PM   #4
Seebeck Voltages
anyone else?
I have checked this in matlab, and with other people, getting the same answer.
but the LabVIEW VI software in the lab gives us the right answer
Sep6-05, 07:04 AM   #5
Recognitions:
Looking at my ASTM tc reference, the K type polynomial is different than what you have. Give me a bit and I'll post it.
Sep6-05, 07:51 AM   #6
OK, thanks.
I pulled mine from National Instruments documentation on thermocouples, but I will be interested to see yours.
Sep6-05, 09:01 AM   #7
Recognitions:
Without running some numbers I can't say if this will fix your offset, but I did forget that there are two exponential corrections for the first two terms. Take a look at the attached page.
Also note the reference temperature of 0°
Ref. ASTM Manual on the use of thermocouples in temperature measurement, 4th edition.
Sep6-05, 07:56 PM   #8
Thanks for that, but the problem with that is that converts from temp to volts, i need to go the other way.
Sep7-05, 07:56 AM   #9
Recognitions:
All right. Let me see what else I can dig up.
Sep8-05, 06:35 AM   #10
Recognitions:
OK. Try this one. Hopefully this one will help. This is from NIST. It is a typical K type TC table, however at the very end there is a section for the inverse function of temp and emf. Give that a look see and maybe that will hlp you out.
Thread Closed
Similar discussions for: Seebeck Voltages
Thread Forum Replies
Seebeck Effect a bit of a puzzler Classical Physics 2
Seebeck effect and hot-probe test General Physics 0
Seebeck coefficeints Classical Physics 1
Pyroelectricity=Peltier-Seebeck effect? General Physics 2
