Remote Control + Head = further distance?
The discussion centers around the phenomenon of increased range when using remote controls, particularly when held against the head. Participants explore potential explanations for this observation, including antenna orientation, body effects on signal transmission, and other speculative theories. The scope includes technical reasoning, conceptual exploration, and anecdotal experiences related to radio frequency (RF) remotes.
  • Some participants suggest that the orientation of the remote's antenna relative to the receiver's antenna may affect signal reception, potentially explaining the increased range.
  • Others argue that the head itself cannot significantly amplify radio waves due to its size relative to the wavelength of the signals involved.
  • A participant proposes that the body may act as an extension of the remote's antenna, enhancing signal transmission when in contact with the remote.
  • Some participants speculate about the possibility of undiscovered telekinetic abilities affecting the signal, though this is met with skepticism.
  • An antenna engineer notes that the head could alter the radiation pattern of the remote, potentially concentrating the signal in a favorable direction.
  • Another participant raises the idea that raising the remote to a higher position might improve line-of-sight to the receiver, although this contradicts other examples where receivers are at different heights.
  • One participant discusses the role of capacitance in radio circuits and how proximity to the body can affect the circuit's performance.
  • Several participants share personal experiences, with some confirming improved range when holding the remote to their head, while others do not observe a significant effect.
Participants express a range of views on the topic, with no consensus reached. Some agree on the potential influence of antenna orientation and body effects, while others challenge the validity of these explanations and propose alternative theories.
Limitations include varying personal experiences with remote range, dependence on specific remote types, and the lack of controlled experiments to validate claims. The discussion also highlights the complexity of radio wave behavior and the influence of environmental factors.
juming
huh?
has anyone else noticed this? I'm sure you have?
has anyone got an explanation for it?
like... when you put your car remote, you get about 10ft more range from it... or a garage door remote, about another 30ft when you put it against your temple.
i'm sure this has been asked before, but i can't find the answer...
... I've never put remote controls up to my head so "huh?" is about right for me.
I heard of a possible explanation via NPR's "Car Talk": It is not so much that you put the remote next to your head, it's that you change the orientation of the remote. If the sending antenna inside the remote is in a horizontal position, but the receiving antenna in the garage door opener is oriented vertically, the signal will not be received with as much intensitiy as when the two antennas are similarly alligned.
This is only what I heard, and the two guys are MIT graduates (tho they act like idiots). But I can't think of a better explanation, and I really really really don't believe the head (with a maximum diameter of 25 cm, tops) can have any amplifying effect on a radio wave that is tens or hundreds of meters in wavelength.
to: Pengwuino
try it... it works! obviously not IR remotes, but RF remotes
to: Chi Meson
your MIT grad's might be idiots because although that makes sense, it surely won't add between 3-30ft extra range?
i drive down the street, its a curved street... and it never opens the garage door before about 20m unless i put the remote to my head... regardless of the orientation of the remote...
+ your common garden-variety RF remote operates at 433MHz if I'm not mistaken. if i am mistaken, slap me!
A frequency of 433MHz has a wavelength of 69.236cm... and my head's definitely not that big!
what about your brain or undiscovered telekenetic abilities
i know this may sound crazy but evolution may create these ways we can manipulate space time. Mabey this is one of the first cases of it. Well a radio wave is composed of relativly small particles so mabey could be amplified by our own intentions in our consciousness
Please do not turn this into a crackpot theory or it WILL be locked! Read our PF guideline that you have explictly agreed to before posting.
Zz.
juming said:
to: Chi Meson
I have a remote garage door opener too. I have never gotten better range by pointing the thing at my head. I have gotten better range by changing the orientation (never 30 feet tho). I believe there to be some other explanation that is rational and scientifically supportive.
Speaking as an antenna engineer, your head will affect the radiation pattern of
the remote. It may end up concentrating the signal in some direction and if the
receiver is on the edge of detection it will get enough of a boost to operate the
door.
door.
By radiation pattern are you referring to "near field" radiation, etc?
And can your skull act like a parabolic mirror for radio waves? I'm very curious as to how this could happen. Could you elaborate?
TIA
re: Chi Meson
i don't mean point it at your head, i mean hold it against your temple
re: "And can your skull act like a parabolic mirror for radio waves?"
that's what i thought the answer was... just how it does that, i don't know :/
juming said:
re: Chi Meson
As far as I know, it couldn't. Since radiowaves, at there shortest, are meters in length, the size of the skull is far too small to cause significant reflection, regradless of the non-parabolic shape.
It did just occur to me that since touching the antenna on a TV, for instance, will enhance reception, perhaps touching the remote allows the body to become an extension of the transmission antenna. This means it is not the head that does it, per se, but the whole body.
Anyone? Have the Mythbusters taken this one on?
TIA
Not like a parabolic antenna. More like a one-element director/reflector
pair. Look up Yagi-Uda dipole arrays.
One of the main components of any radio tuner is called the "LC Tank" or "LC circuit". http://en.wikipedia.org/wiki/LC_circuit It's a very simple circuit and the frequency it resonates to (is tuned to) is given by:
f = 1/(2*pi(sqrt(LC)))
You can't really have much effect on "L" the unless you come into direct contact with the circuit. "C" however is the capacitance and will be affected by conductive bodies close to it. Proximity relationship is exponential... that is 1" away is far more of an effect that twice the effect from 2" away. So as your body comes into contact with the plastic body of the fob the value of C has now changed.
This effect is often experienced in a noticeable way when trying to tune a radio to a weak signal. Every time you get it just right you move your hand away and it goes out of tune. You can often beat this problem by tuning the radio slightly off station... when you remove your hand it will detune it to the right frequency.
Engineers who manufacture these fobs will make them slightly detuned knowing you need to put your hand into contact to operate it. Putting it close to the mass of your body, your head or your torso, increases this effect thus increasing range.
Perhaps raising the remote to your temple gives it an extra 1-2 feet of height, which would put its LOS closer to your garage receiver, but this is opposite to your car example where most receivers are (waist high?).
Also, another random possibility is there is much street level radiation noise 3-4 feet above street level, but for whatever reason(s), 5-6 feet has much less noise that would interfere with your remote's signal.
That's all I can think of.
The simple test for this is to hold the remote at the same height and orientation but not near your head. This has no range increasing effect. Similarly you can hold it in the same as normal orientation but against your torso... range will be improved.
Try these things... I have. I stand by my posit above.
Jed EE
Jed EE
So its not an issue of the remote being closer to your head, so much as it is whether the remote is close to your body. I don't see a big mystery to this. If your body is a better conductor than air, which it is, the closer your move a remote to its central bulk, the higher the amplitude of your signal will be.
Why?
You see this claim that you make is true... but why? If you don't know why this is a big mystery... to you anyway.
The answer is above.
  • · Replies 17 ·
  • · Replies 23 ·
14K
