Calculating Displacement: X Component Error
The discussion focuses on calculating the x component of a car's displacement after it travels 2.2 km in the x-direction and then turns left 67.5 degrees to travel an additional 3.09 km. The initial calculation incorrectly negated the x component of the second vector, which should have been positive since the car is moving in the northeast direction. The correct x component for the second vector is found by multiplying the cosine of 67.5 degrees by 3.09, resulting in a positive value. The final x component of the car's displacement is the sum of 2.2 km and the corrected x component from the second vector.
  • Understanding of vector components and displacement
  • Knowledge of trigonometric functions, specifically cosine
  • Ability to perform vector addition
  • Familiarity with angle measurement in degrees
  • Review vector addition techniques in physics
  • Study trigonometric functions and their applications in vector calculations
  • Practice problems involving displacement and direction changes
  • Learn about the implications of angle direction on vector components
Students studying physics, particularly those focusing on kinematics and vector analysis, as well as educators teaching these concepts.
AdnamaLeigh
I thought I calculated the vector components correctly and added them, but apparently something is wrong.
A car travels 2.2 km in the x-direction, then turns left 67.5 degrees to the original direction and travels an additional distance of 3.09km. Calculate the x component of the car's displacement.
This is what I did:
The first vector went 2.2km to the right, so the x component of that vector is 2.2, while the y is 0. Unless I misread the info, the second vector is going 3.09km in the northwest direction. I found the x component of that by multiplying the cosine of 67.5 by -3.09 (negative because it is going in the negative x-axis direction, or so that's how my book explains it). I got -1.182. The y component is unncecessary but I got 2.855 for that. I added the two x components up and I got 1.018 and it's incorrect. I don't know where I went wrong.
If the car turns through an angle of less than 90 degrees its x-component is still positive. You should not have negated 3.09.
Yeah, you're right. It's going in the NE direction. I completely messed that up, I feel like a moron. Thanks
  • · Replies 21 ·
  • · Replies 19 ·
