Sinusoidal electric field and a sphere
The discussion focuses on the scattering of electromagnetic waves from a dielectric sphere in a sinusoidal electric field, a more realistic scenario than a constant field. Key concepts include Rayleigh and Mie scattering, where Rayleigh scattering approximates scattering points as dipoles, while Mie scattering applies to larger particles and requires solving Maxwell's equations with specific boundary conditions. The conversation highlights the importance of the particle's size relative to the wavelength in determining the scattering regime. Reilly Atkinson emphasizes the need for spherical coordinate expressions and matching interior and exterior fields at the sphere's surface.
  • Understanding of Rayleigh and Mie scattering theories
  • Familiarity with Maxwell's equations
  • Knowledge of spherical coordinates and Bessel functions
  • Basic concepts of dipole radiation
  • Study the Weyl expansion for plane waves in spherical coordinates
  • Learn about the boundary conditions for dielectric spheres in electromagnetic theory
  • Explore the multipole expansion in electromagnetic scattering
  • Investigate the implications of wavelength on scattering regimes
Students and professionals in electromagnetics, physicists studying wave scattering, and engineers working with dielectric materials in varying electric fields.
Ido
A simple question in Electrodynamics is finding the scattering field of a dielectric sphere in constant electric field.
I'm interested in a simple generalization of the above question:
dielectric sphere in sinusoidal electric field.
This problem is much more usefull and even realistic.
And a small matter of intuition:
Can I replace it with a dipole?(like we're doing in the above question)
Just off the top of my head, I think the size of the particle relative to the wavelength is of importance, since it determines which scattering 'regime' (for want of a better word) you are in (Rayleigh, Mie etc.).
The theory of Rayleigh scattering approximates scattering points as dipoles, however the theory of Mie scattering (where the particles are larger than those considered for Rayleigh scattering) solve Maxwell's equations with the particular boundary conditions specified by the particle.
Claude.
Ido -- Your problem of the scattering of electromagnetic waves from a dielectric sphere is pretty much a standard problem in advanced E&M courses. In class and in most texts the case of scattering from a conducting sphere is worked out. The dielectric sphere case is often assigned as a homework problem. You can find a detailed approach to the conducting sphere in Jackson, and, I'm sure, in other books as well. The homework problem is to take the conducting sphere computations as a guide for the dielectric case.
There are two major issues: finding a spherical coordinate expression for a plane wave -- the so-called Weyl expansion -- which involves bessel functions and spherical harmonics. Then the interior fields and exterior fields must match and obey the boundary conditions at the sphere's surface. This involves quite a lot of tedious calculations.
In the limit of long wavelengths, the dielectric sphere behaves like a dipole, an electric one and a magnetic one. Roughly speaking, a long wavelength radiation field looks like a constant field -- takes a while to propagate through the sphere, and sort of, the problem becomes briefly like the constant field problem. This type of physical reasoning helps guide the more technical stuff, and indicates possible approximations.
The general solution involves all the multipoles.
Good question.
Regards,
Reilly Atkinson
  • · Replies 73 ·
