Formula for the inverse problem
  • Thread starter Thread starter danielI
    Formula Inverse
The discussion revolves around proving the invertibility of the matrix expression I - A given that A^2 = 0. Participants explore various mathematical concepts related to linear transformations and matrix theory.
  • Some participants suggest using determinants to show that I - A is invertible, while others propose alternative methods, such as Taylor series and properties of linear transformations. Questions about the kernel of the transformation are also raised.
Participants are actively engaging with different approaches to the problem, with some providing hints and others questioning assumptions. There is a mix of suggestions regarding the use of series expansions and properties of matrices, indicating a productive exploration of the topic.
There is a mention of constraints related to the properties of A, specifically that A^2 = 0, which influences the discussion on convergence and the nature of the inverse. Additionally, the concept of the kernel is being examined in the context of invertibility.
danielI
If [tex]A^2 = 0[/tex], show that [tex]I - A[/tex] is invertible.
So we know that [tex]\det(A^2) = (\det A)^2 = \det 0 \Leftrightarrow \det A = 0[/tex]
We should now show that [tex]\det(I-A) \not= 0[/tex].
But I'm not sure how to do that. Could someone kick me in the right directon?
There's no need for determinants here. There is a very simply formula for the inverse of I - A (when A^2 = 0). Any further hints will practically give away the entire solution, but (I - A)^(-1) "looks" a lot like I - A...
forget matrices for one second, think taylor series
what is (1-x)^{-1} as a series expansion when |x|<1?
This can be suitably altered to tell us what the inverse of 1-A is for any A up to some convergence questions. Since A^2=0 these convergence questions vanish entirely as they do if instead of A^2=0 we had A^r=0
obviously since you have been given r=2 i could be using something, talyor series, you've never heard of, and instead you are supposed to use something that, up to making a sign change, is what Muzza said (difference of two squares, anyone?)
and you don't have to be clever. try showing I-A has no kernel. this suffices at least in finite dimensions.
http://www.ugrad.math.ubc.ca/coursedoc/math101/notes/series/taylor.html
[tex](I-A)^{-1}=(I+A)\text{, since }A^n=A^2\cdot A^{n-2} = 0\cdot A^{n-2}=0[/tex]
[tex](I - A)(I + A) = II + IA - AI - AA = I + A - A - 0 = I[/tex]
[tex](I + A)(I - A) = II - IA + AI - AA = I - A + A - 0 = I[/tex]
Now when I've solved this problem I would like to see your solutions (if it's different). It's allways good to learn more ways to solve a problem :smile:
mathwonk: exactly what do you mean by 'kernel'?
The "kernel" of a linear transformation (or any function, for that matter) is the subset of the domain that get taken to 0: {x| f(x)= 0}. If a function is invertible, it must be one-to-one and (since for any f a linear transformation, f(0)=0) so the kernel of an invertible linear transformation can only be {0}.
Mathwonk's solution goes a little like this:
suppose that (1-A)x=0, that is x is in the kernel, then that is the same as x=Ax, but now apply A to both sides, what happens? Now, if U and V are zero what is U+V?
  • · Replies 20 ·
  • · Replies 18 ·
