Heat Transfer Problem in Cylindrical
The discussion revolves around a steady-state heat transfer problem in cylindrical coordinates, specifically focusing on determining the temperature at the center of a thin disc with a given average boundary temperature. The original poster expresses difficulty in understanding the problem setup and the application of Laplace's equation.
  • Participants discuss the implications of assuming temperature independence from the angular coordinate and the application of Laplace's equation. There are inquiries about the periodicity of sine and cosine functions and how boundary conditions influence the solution.
The discussion is ongoing, with some participants providing hints and clarifications regarding the mathematical framework needed to approach the problem. There is no explicit consensus, but guidance has been offered on how to proceed with the boundary conditions and the general solution.
Participants note that the problem's setup assumes certain conditions, such as the temperature distribution being independent of the angular coordinate and the potential implications of maintaining a constant temperature along the cylindrical wall.
danai_pa
I don't understand this problem. I think it is difficult for me. Please anyone
suggestion this problem to me. Thanf you
Let us cosider steady state heat transfer problem in which laplaceT(r)=0
What is the temparature at the center of a thin disc of radius a
whose average boundary temparatue is 70 degree?
Hint:
1) Assume that the temperature distribution is independent of the direction
along the cylinder
2) Use Laplace equation in cylindrical coordinates
3) the temperature at the center is determined from the temperature
distribution for which r=0
4) The functions Sin beta(x) and Cos beta(x) have a periodicity if and only if
the values of beta are integer
5) The average boundary temperature at r=a is given by
T(average) = 1/2*Pi intregrate from 0 to 2*Pi [(T(a,seta)d(seta)]
Anyone please help me. I don't understand this problem. Thankyou
along the cylinder
That means that [itex]T[/itex] is a function of [itex]r[/itex] only, and not [itex]\theta[/itex].
Laplace's equation is [itex]\nabla^2T=0[/itex]. Look up the Laplacian in cylindrical coordinates and write down the equation for [itex]T=T(r)[/itex].
Apply this boundary condition after you get a general solution for [itex]T(r)[/itex].
We'll get to this after you complete #3.
Since you're solving a 2nd order Diff Eq, you need 2 pieces of information to eliminate the 2 arbitrary constants that arise. The first piece was in Hint 3, and this is the other one.
Please try the problem. If you get stuck, let us know how you started and how far you got.
Why this problem is not depent on seta. and h ?
Because the problem says so. You could achieve this by holding the cylindrical wall at a constant temperature.
