| Thread Closed |
[SOLVED] where does newtons laws fail |
Share Thread | Thread Tools |
| Sep7-05, 01:25 AM | #1 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>iam really searching for the answer where does newtons laws fail.i came\nto know that in some cases without the application of force there may\nbe change in the momentum of the particle.how can this happen .can any\none quote the example.\nwhat is a virtual work and how could it be possible.\nthaks for ur valuable time\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>iam really searching for the answer where does newtons laws fail.i came
to know that in some cases without the application of force there may be change in the momentum of the particle.how can this happen .can any one quote the example. what is a virtual work and how could it be possible. thaks for ur valuable time |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep8-05, 12:36 PM | #2 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>In article <1125735134.153451.18680@g43g2000cwa.googlegroups.com>,\nimsphy9@ gmail.com says...\n> iam really searching for the answer where does newtons laws fail.i came\n> to know that in some cases without the application of force there may\n> be change in the momentum of the particle.how can this happen .can any\n> one quote the example.\n> what is a virtual work and how could it be possible.\n> thaks for ur valuable time\n\nProbably you are being confused by some poor quality explanation of\nsome part of physics (could be one of several fields as far as I can\nsee) that is using terms without explaining them properly, or how they\nrelate to other theories.\n\nI *think* the discussion is probably about forces being explained by\nthe exchange of virtual bosons. This doesn\'t actually mean Newton\'s\nlaw - or definition - f=ma fails at some point. It means it\'s being\nexplained by a different model of how forces work. [I will also point\nout that a relativistic version of f=ma is still built into the new\ntheory, even if strange things are done with it.]\n\nLet me give a simple example: I say "water doesn\'t evaporate, the\nfaster atoms escape from the liquid". Am I saying that the ordinary\ntheory of evaporation "added heat converts water into vapour with a\ncertain latent heat of evaporation" is wrong or fails at some point?\nNo - I\'m explaining the same phenomenon in a different way.\n\nThe term \'virtual work\' actually indicates a bad jumble of unrelated\nconcepts - we don\'t need the term work unless we are operating on a\nscale above that of virtual particle interactions. We can talk about\nmomentum of virtual particles, but the only need for the term work is\nin the context of energy and entropy in thermodynamics, which is\nprecisely to do with the scale in which the interference effects of\nvirtual particles have been cancelled out, and real particles have been\nmeasured. And any real particle you measure will honour f=ma very\nwell, allowing for a little residual quantum uncertainty that\ndefinitely can\'t be harnessed to do actual work.\n\n- Gerry Quinn\n\n\n\n\n\n\n\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>In article <1125735134.153451.18680@g43g2000cwa.googlegroups.com>,
imsphy9@gmail.com says... > iam really searching for the answer where does newtons laws fail.i came > to know that in some cases without the application of force there may > be change in the momentum of the particle.how can this happen .can any > one quote the example. > what is a virtual work and how could it be possible. > thaks for ur valuable time Probably you are being confused by some poor quality explanation of some part of physics (could be one of several fields as far as I can see) that is using terms without explaining them properly, or how they relate to other theories. I *think* the discussion is probably about forces being explained by the exchange of virtual bosons. This doesn't actually mean Newton's law - or definition [itex]- f=ma[/itex] fails at some point. It means it's being explained by a different model of how forces work. [I will also point out that a relativistic version of [itex]f=ma[/itex] is still built into the new theory, even if strange things are done with it.] Let me give a simple example: I say "water doesn't evaporate, the faster atoms escape from the liquid". Am I saying that the ordinary theory of evaporation "added heat converts water into vapour with a certain latent heat of evaporation" is wrong or fails at some point? [itex]No -[/itex] I'm explaining the same phenomenon in a different way. The term 'virtual work' actually indicates a bad jumble of unrelated concepts [itex]- we[/itex] don't need the term work unless we are operating on a scale above that of virtual particle interactions. We can talk about momentum of virtual particles, but the only need for the term work is in the context of energy and entropy in thermodynamics, which is precisely to do with the scale in which the interference effects of virtual particles have been cancelled out, and real particles have been measured. And any real particle you measure will honour [itex]f=ma[/itex] very well, allowing for a little residual quantum uncertainty that definitely can't be harnessed to do actual work. - Gerry Quinn |
| Sep10-05, 10:09 AM | #3 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>Gerry Quinn wrote:\n> In article <1125735134.153451.18680@g43g2000cwa.googlegroups.com>,\n> imsphy9@gmail.com says...\n> > iam really searching for the answer where does newtons laws fail.i came\n> > to know that in some cases without the application of force there may\n> > be change in the momentum of the particle.how can this happen .can any\n> > one quote the example.\n> > what is a virtual work and how could it be possible.\n> > thaks for ur valuable time\n>\n> Probably you are being confused by some poor quality explanation of\n> some part of physics (could be one of several fields as far as I can\n> see) that is using terms without explaining them properly, or how they\n> relate to other theories.\n>\n> I *think* the discussion is probably about forces being explained by\n> the exchange of virtual bosons. This doesn\'t actually mean Newton\'s\n> law - or definition - f=ma fails at some point. It means it\'s being\n> explained by a different model of how forces work. [I will also point\n> out that a relativistic version of f=ma is still built into the new\n> theory, even if strange things are done with it.]\n>\n> Let me give a simple example: I say "water doesn\'t evaporate, the\n> faster atoms escape from the liquid". Am I saying that the ordinary\n> theory of evaporation "added heat converts water into vapour with a\n> certain latent heat of evaporation" is wrong or fails at some point?\n> No - I\'m explaining the same phenomenon in a different way.\n>\n> The term \'virtual work\' actually indicates a bad jumble of unrelated\n> concepts - we don\'t need the term work unless we are operating on a\n> scale above that of virtual particle interactions. We can talk about\n> momentum of virtual particles, but the only need for the term work is\n> in the context of energy and entropy in thermodynamics, which is\n> precisely to do with the scale in which the interference effects of\n> virtual particles have been cancelled out, and real particles have been\n> measured. And any real particle you measure will honour f=ma very\n> well, allowing for a little residual quantum uncertainty that\n> definitely can\'t be harnessed to do actual work.\n>\n> - Gerry Quinn\n\nIs the question about the D\'Alembert\'s Principle, isn\'t it?\nAlain J. Brizard wrote a nice Introduction to Lagrangian and\nHamiltonian\nmechanics:\nhttp://academics.smcvt.edu/abrizard/Classical_Mechanics/CM.htm\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>Gerry Quinn wrote:
> In article <1125735134.153451.18680@g43g2000cwa.googlegroups.com>, > imsphy9@gmail.com says... > > iam really searching for the answer where does newtons laws fail.i came > > to know that in some cases without the application of force there may > > be change in the momentum of the particle.how can this happen .can any > > one quote the example. > > what is a virtual work and how could it be possible. > > thaks for ur valuable time > > Probably you are being confused by some poor quality explanation of > some part of physics (could be one of several fields as far as I can > see) that is using terms without explaining them properly, or how they > relate to other theories. > > I *think* the discussion is probably about forces being explained by > the exchange of virtual bosons. This doesn't actually mean Newton's > law - or definition [itex]- f=ma[/itex] fails at some point. It means it's being > explained by a different model of how forces work. [I will also point > out that a relativistic version of [itex]f=ma[/itex] is still built into the new > theory, even if strange things are done with it.] > > Let me give a simple example: I say "water doesn't evaporate, the > faster atoms escape from the liquid". Am I saying that the ordinary > theory of evaporation "added heat converts water into vapour with a > certain latent heat of evaporation" is wrong or fails at some point? > [itex]No -[/itex] I'm explaining the same phenomenon in a different way. > > The term 'virtual work' actually indicates a bad jumble of unrelated > concepts [itex]- we[/itex] don't need the term work unless we are operating on a > scale above that of virtual particle interactions. We can talk about > momentum of virtual particles, but the only need for the term work is > in the context of energy and entropy in thermodynamics, which is > precisely to do with the scale in which the interference effects of > virtual particles have been cancelled out, and real particles have been > measured. And any real particle you measure will honour [itex]f=ma[/itex] very > well, allowing for a little residual quantum uncertainty that > definitely can't be harnessed to do actual work. > > - Gerry Quinn Is the question about the D'Alembert's Principle, isn't it? Alain J. Brizard wrote a nice Introduction to Lagrangian and Hamiltonian mechanics: http://academics.smcvt.edu/abrizard/...chanics/CM.htm |
| Sep21-05, 03:54 PM | #4 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>jaan wrote:\n> iam really searching for the answer where does newtons laws fail.\n\nThe infrastructure underlying Newton\'s Laws fails -- that is: the\nstructure of its spacetime.\n\nUse the word "event" in the following to denote that which is\ncharacterized by a position and time -- a point-instant.\n\nNewton\'s laws presume a spacetime amongst whose features includes the\nfollowing ones of significance:\n\n* Spacetime has the form of a sequence of 3-dimensional snapshots, each\nrepresenting "space" at a given "time"\n\n* The past of any event is ALL of space on all the snapshots preceding\nthat which the event lies on\n\n* The future of any event is ALL of space on all the snapshots\npreceding that which the event lies on\n\n* A hypothetical object travelling at an infinite speed in one frame of\nreference would be doing so in all frames of reference. Infinity is an\ninvariant speed. All finite speeds are relative.\n\n* To say the same thing another way: two events simultaneous in one\nframe of reference are simultaneous in all frames of reference.\n\n* To say the same thing a third way: for a given event, the\nneither-past-nor-future of the event comprises a 3-dimensional space --\nnamely, the snapshot the event lies on.\n\n* To say the same thing a fourth way: if A, B, C are events and A is\nneither past nor future of B, B is neither past nor future of C, then A\nis neither past nor future of C.\n\nThe contrast to Relativity is this:\n* The past of any event is a sphere (and its inside) that contracts\ndown at light speed to the event, itself -- the past light cone of the\nevent.\n\n* The future of the event is a sphere (and its inside) that expands at\nlight speed from the event, itself -- the future light cone of the\nevent.\n\n* The invariant speed is FINITE. Not all finite speeds are relative,\nwhich makes the name "Relativity" of the theory entirely inappropriate,\nas Einstein pointed out early on.\n\n* Infinity is NOT an invariant speed, it\'s relative.\n\n* The neither-past-nor-future of a given event is a FOUR dimensional\ncontinuum -- namely the outside of the past and future light cones of\nthe event.\n\n* It is possible for A, B, C to be events with A neither before nor\nafter\nB, B neither before nor after C, but A before C. (Example: A = the\nEarth at a specific time, C = the Earth 1 second later; B = the Moon at\none of a specific range of times within the approximate 2 second window\nof its existence that lies outside the light cones of A and C).\n\nThe two spacetimes are known, respectively, as Galilean and Minkowski\nspacetime.\n\nIn the process of trying to retrofit Newton\'s Laws to Minkowski\nspacetime, this forces the concepts of energy and momentum to be\nunified into a single entity -- the 4-momentum. The law of inertia has\nto be suitably modified and extended; with the additional condition\nthat a quantity, U, of energy must be associated with a mass equal to\nU/c^2, where c is light speed.\n\nIn Newtonian spacetime, the two separate concepts of kinetic energy\n(Lagrangian and Hamiltonian) for a body are equal, the equivalence\nexpressed by L = H; where L and H are related by the Legendre transform\nH = pv - L, and the momentum and velocity by the relation p = mv.\n\nThis implies that L = mv^2/2; H = p^2/2m.\n\nIn Relativity, these two concepts split. The Hamiltonian is larger\nthan the Lagrangian, since it also includes the contribution provided\nby the mass equivalent of the total energy of the Hamiltonian, itself.\nSo, they lie in a ratio, H/(m + H/c^2) = L/m, where m is the rest mass\nof the body.\n\nLikewise, the momentum carries this additional contribution: p = (m +\nH/c^2) v.\n\nSince L and H are related by the Legendre transform, H = pv - L, this\nimplies that\nH/(m + H/c^2) = L/m; L = (m + H/c^2)v^2 - H\nwhose solution is\nL = mv^2/(1 + (1 - (v/c)^2)^{1/2})\n= mc^2 - mc^2 (1 - (v/c)^2)^{1/2}\n\nH = p^2/((p/c)^2 + m^2)^{1/2} + m)\n= mc^2/(1 - (v/c)^2)^{1/2} - mc^2.\nSo, it\'s natural to identify mc^2 as the rest energy of the body and\nequate the total kinetic energy to H + mc^2, which is\nE = H + mc^2 = mc^2/(1 - (v/c)^2)^{1/2}.\nThe momentum is thus\np = mv/(1 - (v/c)^2)^{1/2}\nand (E, p) form the components of the momentum 4-vector.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>jaan wrote:
> iam really searching for the answer where does newtons laws fail. The infrastructure underlying Newton's Laws fails -- that is: the structure of its spacetime. Use the word "event" in the following to denote that which is characterized by a position and time -- a point-instant. Newton's laws presume a spacetime amongst whose features includes the following ones of significance: * Spacetime has the form of a sequence of 3-dimensional snapshots, each representing "space" at a given "time" * The past of any event is ALL of space on all the snapshots preceding that which the event lies on * The future of any event is ALL of space on all the snapshots preceding that which the event lies on * A hypothetical object travelling at an infinite speed in one frame of reference would be doing so in all frames of reference. Infinity is an invariant speed. All finite speeds are relative. * To say the same thing another way: two events simultaneous in one frame of reference are simultaneous in all frames of reference. * To say the same thing a third way: for a given event, the neither-past-nor-future of the event comprises a 3-dimensional space -- namely, the snapshot the event lies on. * To say the same thing a fourth way: if A, B, C are events and A is neither past nor future of B, B is neither past nor future of C, then A is neither past nor future of C. The contrast to Relativity is this: * The past of any event is a sphere (and its inside) that contracts down at light speed to the event, itself -- the past light cone of the event. * The future of the event is a sphere (and its inside) that expands at light speed from the event, itself -- the future light cone of the event. * The invariant speed is FINITE. Not all finite speeds are relative, which makes the name "Relativity" of the theory entirely inappropriate, as Einstein pointed out early on. * Infinity is NOT an invariant speed, it's relative. * The neither-past-nor-future of a given event is a FOUR dimensional continuum -- namely the outside of the past and future light cones of the event. [itex]* It[/itex] is possible for A, B, C to be events with A neither before nor after B, B neither before nor after C, but A before C. (Example: A = the Earth at a specific time, C = the Earth 1 second later; B = the Moon at one of a specific range of times within the approximate 2 second window of its existence that lies outside the light cones of A and C). The two spacetimes are known, respectively, as Galilean and Minkowski spacetime. In the process of trying to retrofit Newton's Laws to Minkowski spacetime, this forces the concepts of energy and momentum to be unified into a single entity -- the 4-momentum. The law of inertia has to be suitably modified and extended; with the additional condition that a quantity, U, of energy must be associated with a mass equal to [itex]U/c^2,[/itex] where c is light speed. In Newtonian spacetime, the two separate concepts of kinetic energy (Lagrangian and Hamiltonian) for a body are equal, the equivalence expressed by [itex]L = H;[/itex] where L and H are related by the Legendre transform [itex]H = pv - L,[/itex] and the momentum and velocity by the relation [itex]p = mv[/itex]. This implies that [itex]L = mv^2/2; H = p^2/2m[/itex]. In Relativity, these two concepts split. The Hamiltonian is larger than the Lagrangian, since it also includes the contribution provided by the mass equivalent of the total energy of the Hamiltonian, itself. So, they lie in a ratio, [itex]H/(m + H/c^2) = L/m,[/itex] where m is the rest mass of the body. Likewise, the momentum carries this additional contribution: [itex]p = (m +H/c^2) v[/itex]. Since L and H are related by the Legendre transform, [itex]H = pv - L,[/itex] this implies that [itex]H/(m + H/c^2) = L/m; L = (m + H/c^2)v^2 - H[/itex] whose solution is [itex]L = mv^2/(1 + (1 - (v/c)^2)^{1/2})= mc^2 - mc^2 (1 - (v/c)^2)^{1/2}H = p^2/((p/c)^2 + m^2)^{1/2} + m)= mc^2/(1 - (v/c)^2)^{1/2} - mc^2[/itex]. So, it's natural to identify [itex]mc^2[/itex] as the rest energy of the body and equate the total kinetic energy to [itex]H + mc^2,[/itex] which is [itex]E = H + mc^2 = mc^2/(1 - (v/c)^2)^{1/2}.[/itex] The momentum is thus [itex]p = mv/(1 - (v/c)^2)^{1/2}[/itex] and (E, p) form the components of the momentum 4-vector. |
| Sep23-05, 02:59 PM | #5 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE><markwh04@yahoo.com> wrote in message\nnews:1127253670.841926.51930@g44g2000cwa.googlegroups.com...\n > jaan wrote:\n> > iam really searching for the answer where does newtons laws fail.\n>\n> The infrastructure underlying Newton\'s Laws fails -- that is: the\n> structure of its spacetime.\n\nI\'m not sure what is meant above with "Newton\'s spacetime", but in fact,\n*apparent* ("observed") space and time in Newton\'s theory fail at high\nspeeds. One should not confuse transformation rules for observation with the\nunderlying concepts about possible causes.\nThe deviation between observation and prediction was corrected by Lorentz,\nand with that correction (leading to the Lorentz transformations), Newton\'s\nconcept of hidden absolute space and time(=process durations) seems to work\nperfectly well for non-quantum events.\n\nAbout his laws:\nWith the post-Einstein concept of relativistic mass increase it\'s not\nnecessary to retrofit Newton\'s force law F=d(m*v)/dt to Minkowski spacetime,\nas with m=gamma*m_0 it works fine as it stands (that\'s how I learned it,\nfrom the physics text book of Alonso&Finn, 1978). Relativistic mass implies\nchoosing Newton\'s dynamic definition of mass as the definition of mass.\nThere is a never settled debate about Newton\'s third law. It\'s often assumed\nto fail, but experimental confirmation is lacking.\n\nThus with the Lorentz transformations and a convenient definition of mass,\nNewton\'s laws of physics work for any speed in any inertial frame just as\nthey did for low speeds with the Galilean transformations.\n\nPerhaps Newton\'s laws fail in quantum mechanics, but I\'m not knowledgable on\nthat subject.\n\nBest regards,\nHarald\n\n> Use the word "event" in the following to denote that which is\n> characterized by a position and time -- a point-instant.\n>\n> Newton\'s laws presume a spacetime amongst whose features includes the\n> following ones of significance:\n>\n> * Spacetime has the form of a sequence of 3-dimensional snapshots, each\n> representing "space" at a given "time"\n>\n> * The past of any event is ALL of space on all the snapshots preceding\n> that which the event lies on\n>\n> * The future of any event is ALL of space on all the snapshots\n> preceding that which the event lies on\n>\n> * A hypothetical object travelling at an infinite speed in one frame of\n> reference would be doing so in all frames of reference. Infinity is an\n> invariant speed. All finite speeds are relative.\n>\n> * To say the same thing another way: two events simultaneous in one\n> frame of reference are simultaneous in all frames of reference.\n>\n> * To say the same thing a third way: for a given event, the\n> neither-past-nor-future of the event comprises a 3-dimensional space --\n> namely, the snapshot the event lies on.\n>\n> * To say the same thing a fourth way: if A, B, C are events and A is\n> neither past nor future of B, B is neither past nor future of C, then A\n> is neither past nor future of C.\n>\n> The contrast to Relativity is this:\n> * The past of any event is a sphere (and its inside) that contracts\n> down at light speed to the event, itself -- the past light cone of the\n> event.\n>\n> * The future of the event is a sphere (and its inside) that expands at\n> light speed from the event, itself -- the future light cone of the\n> event.\n>\n> * The invariant speed is FINITE. Not all finite speeds are relative,\n> which makes the name "Relativity" of the theory entirely inappropriate,\n> as Einstein pointed out early on.\n>\n> * Infinity is NOT an invariant speed, it\'s relative.\n>\n> * The neither-past-nor-future of a given event is a FOUR dimensional\n> continuum -- namely the outside of the past and future light cones of\n> the event.\n>\n> * It is possible for A, B, C to be events with A neither before nor\n> after\n> B, B neither before nor after C, but A before C. (Example: A = the\n> Earth at a specific time, C = the Earth 1 second later; B = the Moon at\n> one of a specific range of times within the approximate 2 second window\n> of its existence that lies outside the light cones of A and C).\n>\n> The two spacetimes are known, respectively, as Galilean and Minkowski\n> spacetime.\n>\n> In the process of trying to retrofit Newton\'s Laws to Minkowski\n> spacetime, this forces the concepts of energy and momentum to be\n> unified into a single entity -- the 4-momentum. The law of inertia has\n> to be suitably modified and extended; with the additional condition\n> that a quantity, U, of energy must be associated with a mass equal to\n> U/c^2, where c is light speed.\n>\n> In Newtonian spacetime, the two separate concepts of kinetic energy\n> (Lagrangian and Hamiltonian) for a body are equal, the equivalence\n> expressed by L = H; where L and H are related by the Legendre transform\n> H = pv - L, and the momentum and velocity by the relation p = mv.\n>\n> This implies that L = mv^2/2; H = p^2/2m.\n>\n> In Relativity, these two concepts split. The Hamiltonian is larger\n> than the Lagrangian, since it also includes the contribution provided\n> by the mass equivalent of the total energy of the Hamiltonian, itself.\n> So, they lie in a ratio, H/(m + H/c^2) = L/m, where m is the rest mass\n> of the body.\n>\n> Likewise, the momentum carries this additional contribution: p = (m +\n> H/c^2) v.\n>\n> Since L and H are related by the Legendre transform, H = pv - L, this\n> implies that\n> H/(m + H/c^2) = L/m; L = (m + H/c^2)v^2 - H\n> whose solution is\n> L = mv^2/(1 + (1 - (v/c)^2)^{1/2})\n> = mc^2 - mc^2 (1 - (v/c)^2)^{1/2}\n>\n> H = p^2/((p/c)^2 + m^2)^{1/2} + m)\n> = mc^2/(1 - (v/c)^2)^{1/2} - mc^2.\n> So, it\'s natural to identify mc^2 as the rest energy of the body and\n> equate the total kinetic energy to H + mc^2, which is\n> E = H + mc^2 = mc^2/(1 - (v/c)^2)^{1/2}.\n> The momentum is thus\n> p = mv/(1 - (v/c)^2)^{1/2}\n> and (E, p) form the components of the momentum 4-vector.\n>\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky><markwh04@yahoo.com> wrote in message
news:1127253670.841926.51930@g44g200...egroups.com... > jaan wrote: > > iam really searching for the answer where does newtons laws fail. > > The infrastructure underlying Newton's Laws fails -- that is: the > structure of its spacetime. I'm not sure what is meant above with "Newton's spacetime", but in fact, *apparent* ("observed") space and time in Newton's theory fail at high speeds. One should not confuse transformation rules for observation with the underlying concepts about possible causes. The deviation between observation and prediction was corrected by Lorentz, and with that correction (leading to the Lorentz transformations), Newton's concept of hidden absolute space and time(=process durations) seems to work perfectly well for non-quantum events. About his laws: With the post-Einstein concept of relativistic mass increase it's not necessary to retrofit Newton's force law [itex]F=d(m*v)/dt[/itex] to Minkowski spacetime, as with [itex]m=\gamma*m_0 it[/itex] works fine as it stands (that's how I learned it, from the physics text book of Alonso&Finn, 1978). Relativistic mass implies choosing Newton's dynamic definition of mass as the definition of mass. There is a never settled debate about Newton's third law. It's often assumed to fail, but experimental confirmation is lacking. Thus with the Lorentz transformations and a convenient definition of mass, Newton's laws of physics work for any speed in any inertial frame just as they did for low speeds with the Galilean transformations. Perhaps Newton's laws fail in quantum mechanics, but I'm not knowledgable on that subject. Best regards, Harald > Use the word "event" in the following to denote that which is > characterized by a position and time -- a point-instant. > > Newton's laws presume a spacetime amongst whose features includes the > following ones of significance: > > * Spacetime has the form of a sequence of 3-dimensional snapshots, each > representing "space" at a given "time" > > * The past of any event is ALL of space on all the snapshots preceding > that which the event lies on > > * The future of any event is ALL of space on all the snapshots > preceding that which the event lies on > > * A hypothetical object travelling at an infinite speed in one frame of > reference would be doing so in all frames of reference. Infinity is an > invariant speed. All finite speeds are relative. > > * To say the same thing another way: two events simultaneous in one > frame of reference are simultaneous in all frames of reference. > > * To say the same thing a third way: for a given event, the > neither-past-nor-future of the event comprises a 3-dimensional space -- > namely, the snapshot the event lies on. > > * To say the same thing a fourth way: if A, B, C are events and A is > neither past nor future of B, B is neither past nor future of C, then A > is neither past nor future of C. > > The contrast to Relativity is this: > * The past of any event is a sphere (and its inside) that contracts > down at light speed to the event, itself -- the past light cone of the > event. > > * The future of the event is a sphere (and its inside) that expands at > light speed from the event, itself -- the future light cone of the > event. > > * The invariant speed is FINITE. Not all finite speeds are relative, > which makes the name "Relativity" of the theory entirely inappropriate, > as Einstein pointed out early on. > > * Infinity is NOT an invariant speed, it's relative. > > * The neither-past-nor-future of a given event is a FOUR dimensional > continuum -- namely the outside of the past and future light cones of > the event. > > [itex]* It[/itex] is possible for A, B, C to be events with A neither before nor > after > B, B neither before nor after C, but A before C. (Example: A = the > Earth at a specific time, C = the Earth 1 second later; B = the Moon at > one of a specific range of times within the approximate 2 second window > of its existence that lies outside the light cones of A and C). > > The two spacetimes are known, respectively, as Galilean and Minkowski > spacetime. > > In the process of trying to retrofit Newton's Laws to Minkowski > spacetime, this forces the concepts of energy and momentum to be > unified into a single entity -- the 4-momentum. The law of inertia has > to be suitably modified and extended; with the additional condition > that a quantity, U, of energy must be associated with a mass equal to > [itex]U/c^2,[/itex] where c is light speed. > > In Newtonian spacetime, the two separate concepts of kinetic energy > (Lagrangian and Hamiltonian) for a body are equal, the equivalence > expressed by [itex]L = H;[/itex] where L and H are related by the Legendre transform > [itex]H = pv - L,[/itex] and the momentum and velocity by the relation [itex]p = mv[/itex]. > > This implies that [itex]L = mv^2/2; H = p^2/2m[/itex]. > > In Relativity, these two concepts split. The Hamiltonian is larger > than the Lagrangian, since it also includes the contribution provided > by the mass equivalent of the total energy of the Hamiltonian, itself. > So, they lie in a ratio, [itex]H/(m + H/c^2) = L/m,[/itex] where m is the rest mass > of the body. > > Likewise, the momentum carries this additional contribution: [itex]p = (m +[/itex] > [itex]H/c^2) v.[/itex] > > Since L and H are related by the Legendre transform, [itex]H = pv - L,[/itex] this > implies that > [itex]H/(m + H/c^2) = L/m; L = (m + H/c^2)v^2 - H[/itex] > whose solution is > [itex]L = mv^2/(1 + (1 - (v/c)^2)^{1/2})[/itex] > [itex]= mc^2 - mc^2 (1 - (v/c)^2)^{1/2}[/itex] > > [itex]H = p^2/((p/c)^2 + m^2)^{1/2} + m)[/itex] > [itex]= mc^2/(1 - (v/c)^2)^{1/2} - mc^2[/itex]. > So, it's natural to identify [itex]mc^2[/itex] as the rest energy of the body and > equate the total kinetic energy to [itex]H + mc^2,[/itex] which is > [itex]E = H + mc^2 = mc^2/(1 - (v/c)^2)^{1/2}[/itex]. > The momentum is thus > [itex]p = mv/(1 - (v/c)^2)^{1/2}[/itex] > and (E, p) form the components of the momentum 4-vector. > |
| Sep27-05, 02:36 PM | #6 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>jaan wrote:\n> iam really searching for the answer where does newtons laws fail.i came\n> to know that in some cases without the application of force there may\n> be change in the momentum of the particle.how can this happen .can any\n> one quote the example.\n> what is a virtual work and how could it be possible.\n> thaks for ur valuable time\n\nNewton\'s laws fails for very fast objects. For example, it cannot tell\nus why muons which have a very short lifetime at rest can survive for a\nlong enough journey from the upper atmosphere to the surface of the\nearth.\n\nNewton\'s law fails for very heavy objects. For example, it cannot tell\nus why the orbit of Mercury precesses.\n\nNewton\'s law fails for very small objects. For example, it cannot tell\nus why the spectrum of the hydrogen atom is the way it is.\n\nAnd of course, when a daily scale phenomenon, such as the specific heat\ncapacity of gases, involves phenomena from any of the above, Newton\'s\nlaw fails to explain that as well.\n\nThere are hundreds of such examples in each of the above four\ncategories which will make any physicist reading this post will say\n"Oh, why doesn\'t he mention that?!". However, those are the basic\nregimes where Newton\'s laws start to give.\n\nCheers,\nSouvik\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>jaan wrote:
> iam really searching for the answer where does newtons laws fail.i came > to know that in some cases without the application of force there may > be change in the momentum of the particle.how can this happen .can any > one quote the example. > what is a virtual work and how could it be possible. > thaks for ur valuable time Newton's laws fails for very fast objects. For example, it cannot tell us why muons which have a very short lifetime at rest can survive for a long enough journey from the upper atmosphere to the surface of the earth. Newton's law fails for very heavy objects. For example, it cannot tell us why the orbit of Mercury precesses. Newton's law fails for very small objects. For example, it cannot tell us why the spectrum of the hydrogen atom is the way it is. And of course, when a daily scale phenomenon, such as the specific heat capacity of gases, involves phenomena from any of the above, Newton's law fails to explain that as well. There are hundreds of such examples in each of the above four categories which will make any physicist reading this post will say "Oh, why doesn't he mention that?!". However, those are the basic regimes where Newton's laws start to give. Cheers, Souvik |
| Sep27-05, 02:37 PM | #7 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>Harry wrote:\n> > The infrastructure underlying Newton\'s Laws fails -- that is: the\n> > structure of its spacetime.\n> I\'m not sure what is meant above with "Newton\'s spacetime",\n\nThat\'s precisely what the rest of the article you\'re replying to\ndescribed in detail; so your reply doesn\'t make much sense unless you\nsimply jumped the gun.\n\nMore commonly, it is known as Galilean spacetime, the corresponding\nprinciple of relativity as Galilean Relativity, and the symmetry group\nanalogous to the Poincare\' symmetry group as the Galilean symmetry\ngroup.\n\n> About his laws:\n> With the post-Einstein concept of relativistic mass increase it\'s [sic]\n> not necessary to retrofit Newton\'s force law F=d(m*v)/dt to Minkowski spacetime,\n\n> as with m=gamma*m_0 it works fine as it stands\n\n... which is precisely what is entailed by the retrofit, as explained\nin the article. Again, the reply doesn\'t make sense since it directly\npreceded the very thing you\'re reiterating ... unless you jumped the\ngun.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky>Harry wrote:
> > The infrastructure underlying Newton's Laws fails -- that is: the > > structure of its spacetime. > I'm not sure what is meant above with "Newton's spacetime", That's precisely what the rest of the article you're replying to described in detail; so your reply doesn't make much sense unless you simply jumped the gun. More commonly, it is known as Galilean spacetime, the corresponding principle of relativity as Galilean Relativity, and the symmetry group analogous to the Poincare' symmetry group as the Galilean symmetry group. > About his laws: > With the post-Einstein concept of relativistic mass increase it's [sic] > not necessary to retrofit Newton's force law [itex]F=d(m*v)/dt[/itex] to Minkowski spacetime, > as with [itex]m=\gamma*m_0 it[/itex] works fine as it stands ... which is precisely what is entailed by the retrofit, as explained in the article. Again, the reply doesn't make sense since it directly preceded the very thing you're reiterating ... unless you jumped the gun. |
| Oct1-05, 03:31 AM | #8 |
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE><markwh04@yahoo.com> wrote in message\nnews:1127767092.916343.156150@g14g2000cwa.googlegroups.com...\ n> Harry wrote:\n> > > The infrastructure underlying Newton\'s Laws fails -- that is: the\n> > > structure of its spacetime.\n> > I\'m not sure what is meant above with "Newton\'s spacetime",\n>\n> That\'s precisely what the rest of the article you\'re replying to\n> described in detail; so your reply doesn\'t make much sense unless you\n> simply jumped the gun.\n\nI replied to your reply to a question about Newton\'s laws; that posting\nhas not appeared in my newsreader but it\'s the subject header. From your\nfull reply I wasn\'t sure if you you meant Newton\'s concepts of Space and\nTime, or his assumption that Galilean transformation rules are valid for\nall speeds. As I indicated, what has failed was his accompanying\nassumption (based on observation of that time) that speed has no effect\non objects. With Lorentz\' relativistic corrections, there is no problem\nwith the structure of Newton\'s Space and Time. Text books often mislead\npeople into thinking that Newton\'s Space and Time concepts failed (or\nthey don\'t even mention it), and that his concepts must be replaced by\nMinkowski\'s Spacetime. See also the recent threads "logical\ninconsistency in Lorentz\' theory" and Ilja\'s comments in "why isn\'t the\nmathematician Henri Poincare acknowledged as the true discoverer of\nspecial relativity?".\n\n> More commonly, it is known as Galilean spacetime, the corresponding\n> principle of relativity as Galilean Relativity, and the symmetry group\n> analogous to the Poincare\' symmetry group as the Galilean symmetry\n> group.\n\nI didn\'t know that Galileo had such Newtonian concepts. If so, Newton\nwas misleading his readers when he claimed in his introduction of the\nPrincipia:\n\n"I do not define time, space, place and motion, as being well known to\nall."\n\nI suppose that Newton was truthful, and that common jargon is\nmisleading. But if someone has a quote of Galileo that shows the\ncontrary, I\'ll be glad to see it.\n\n> > About his laws:\n> > With the post-Einstein concept of relativistic mass increase it\'s [sic]\n> > not necessary to retrofit Newton\'s force law F=d(m*v)/dt to Minkowski\nspacetime,\n>\n> > as with m=gamma*m_0 it works fine as it stands\n>\n> .. which is precisely what is entailed by the retrofit, as explained\n> in the article. Again, the reply doesn\'t make sense since it directly\n> preceded the very thing you\'re reiterating ... unless you jumped the\n> gun.\n\nWe agree on the math. However, the difference between Minkowski\'s\nSpacetime and Newton\'s Space and Time is conceptual (metaphysical) and\nnot mathematical (physics). You seemed to suggest that one has to use\nthe first in order to do correct physics calculations. Sorry if I\nmisunderstood you. Still, many people confuse those things so that it is\nuseful to point it out now and then.\n\nCheers,\nHarald\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form"> View this Usenet post in original ASCII form </a></div><P></jabberwocky><markwh04@yahoo.com> wrote in message
news:1127767092.916343.156150@g14g20...egroups.com... > Harry wrote: > > > The infrastructure underlying Newton's Laws fails -- that is: the > > > structure of its spacetime. > > I'm not sure what is meant above with "Newton's spacetime", > > That's precisely what the rest of the article you're replying to > described in detail; so your reply doesn't make much sense unless you > simply jumped the gun. I replied to your reply to a question about Newton's laws; that posting has not appeared in my newsreader but it's the subject header. From your full reply I wasn't sure if you you meant Newton's concepts of Space and Time, or his assumption that Galilean transformation rules are valid for all speeds. As I indicated, what has failed was his accompanying assumption (based on observation of that time) that speed has no effect on objects. With Lorentz' relativistic corrections, there is no problem with the structure of Newton's Space and Time. Text books often mislead people into thinking that Newton's Space and Time concepts failed (or they don't even mention it), and that his concepts must be replaced by Minkowski's Spacetime. See also the recent threads "logical inconsistency in Lorentz' theory" and Ilja's comments in "why isn't the mathematician Henri Poincare acknowledged as the true discoverer of special relativity?". > More commonly, it is known as Galilean spacetime, the corresponding > principle of relativity as Galilean Relativity, and the symmetry group > analogous to the Poincare' symmetry group as the Galilean symmetry > group. I didn't know that Galileo had such Newtonian concepts. If so, Newton was misleading his readers when he claimed in his introduction of the Principia: "I do not define time, space, place and motion, as being well known to all." I suppose that Newton was truthful, and that common jargon is misleading. But if someone has a quote of Galileo that shows the contrary, I'll be glad to see it. > > About his laws: > > With the post-Einstein concept of relativistic mass increase it's [sic] > > not necessary to retrofit Newton's force law [itex]F=d(m*v)/dt[/itex] to Minkowski spacetime, > > > as with [itex]m=\gamma*m_0 it[/itex] works fine as it stands > > .. which is precisely what is entailed by the retrofit, as explained > in the article. Again, the reply doesn't make sense since it directly > preceded the very thing you're reiterating ... unless you jumped the > gun. We agree on the math. However, the difference between Minkowski's Spacetime and Newton's Space and Time is conceptual (metaphysical) and not mathematical (physics). You seemed to suggest that one has to use the first in order to do correct physics calculations. Sorry if I misunderstood you. Still, many people confuse those things so that it is useful to point it out now and then. Cheers, Harald |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] where does newtons laws fail
| where does newtons laws fail | General Physics | 0 | ||
