How Can You Calculate Daily Water Loss in a Heated Indoor Spa?
  • Thread starter Thread starter Dan Shenk
    Loss Rate Water
The calculation of daily water loss in a heated indoor spa can be accurately determined by measuring the water level before and after a 24-hour period. This method accounts for fluctuations in spa water temperature, ambient air temperature, and relative humidity. Alternatively, an estimation can be made using the formula: Evaporation Rate = (0.46 x Air Temperature (°C)) + (0.0012 x Relative Humidity) + (0.0006 x Spa Water Temperature (°C)), which calculates evaporation in liters per hour. If the evaporation rate is lower than the measured water loss, further investigation for leaks is warranted.
  • Understanding of basic thermodynamics related to evaporation
  • Familiarity with measuring water levels accurately
  • Knowledge of temperature and humidity measurement tools
  • Ability to perform basic arithmetic calculations
  • Research methods for accurately measuring water levels in spas
  • Learn about humidity and temperature measurement tools
  • Explore advanced evaporation calculation techniques
  • Investigate leak detection methods for spas
Pool maintenance professionals, spa owners, and anyone involved in water conservation or leak detection in heated indoor spas will benefit from this discussion.
Dan Shenk
I am interested in finding how to calculate daily water loss for a heated water spa located in a temperature-controlled pool room. The water volume and surface area are constant. I want to determine the amount of daily water loss as spa water temperature, ambient air temperature, and relative humidity of the pool room fluctuate.
The calculation only needs to be accurate enough to determine if evaporation can account for daily water loss , or if the spa may be leaking.
Thanks for any help or references you can give me on this point.
Dan
The most accurate way to calculate the daily water loss for a heated water spa located in a temperature-controlled pool room would be to measure the water level before and after a 24-hour period and subtract the difference. This will give you the exact amount of water lost in the given time frame and will take into account any fluctuations in spa water temperature, ambient air temperature, and relative humidity. If you do not have access to such measurements, you can also estimate the daily water loss due to evaporation. This can be done by using the formula: Evaporation Rate = (0.46 x Air Temperature (°C)) + (0.0012 x Relative Humidity) + (0.0006 x Spa Water Temperature (°C)) This formula will give you the rate of evaporation over a 24-hour period in liters per hour. You can then multiply this figure by 24 to get the total amount of water lost due to evaporation in a given period of time. If the calculated evaporation rate is lower than the actual water loss, then there may be another source of water loss, such as a leak, that should be investigated.
  • · Replies 18 ·
10K
