Incubating the filters two overnights with primary antibody., WESTERN BLOTTING
  • Thread starter Thread starter mountain
    Filters
Incubating a filter with primary antibody for two overnights before adding a secondary antibody in Western blotting is not advisable. Extended incubation increases the risk of non-specific binding, which can compromise detection accuracy. Instead, it is recommended to block the membrane with a standard blocking solution, rinse with TBST, and store it sealed at 4°C until the primary antibody incubation can be performed according to the protocol. This approach allows for optimal results while accommodating scheduling constraints.
  • Understanding of Western blotting techniques
  • Familiarity with antibody incubation protocols
  • Knowledge of blocking solutions (e.g., milk, BSA)
  • Experience with TBST buffer preparation
  • Research optimal primary antibody incubation times for Western blotting
  • Learn about different blocking solutions and their effects on specificity
  • Explore storage conditions for membranes prior to antibody incubation
  • Investigate methods to minimize non-specific binding in immunodetection
Researchers and laboratory technicians involved in protein analysis, particularly those performing Western blotting and seeking to optimize their antibody detection protocols.
mountain
Is that okey that I incubate the filter with primary antibody two overnights before adding secondary antibody for detection? This is because I do not have the equipment to detect the signals in the weekend so I have to detect it on a Monday. Due to it I incubate the filter with primary antibody on Saturday till Monday morning and then detect the filter on Monday. Would this give me problems?
Biology news on Phys.org
I wouldn't suggest doing this, you will probably end up increasing non-specific binding and thus will limit your detection. I would block the membrane with standard blocking solution (milk, BSA, whatever you use), rinse in TBST (or your other favorite buffer) and then seal it well in plastic wrap and store at 4oC until you can do the primary for the amount of time called for in your protocol. So you could do it Sunday night and then hit it with secondary and whatever detection system you are using on Monday.
  • · Replies 100 ·
10K
  • · Replies 16 ·
  • · Replies 44 ·
16K
