Finding ∫ cscx dx: Tips and Tricks
  • Context: Undergrad
  • Thread starter Thread starter PrudensOptimus
    Dx Integrals
The discussion revolves around finding the integral of csc(x) dx, exploring various methods and techniques for solving this integral. Participants share different approaches, including using integral tables, algebraic manipulation, and substitution methods.
  • Some participants suggest looking up the integral in an integral table, with one mentioning the result as ln(tan(x/2)).
  • Another participant proposes a method similar to that used for integrating sec(x), suggesting a manipulation involving csc(x) and cot(x).
  • One participant describes a more complex approach involving substitution and partial fractions, starting from the expression for csc(x) as 1/sin(x).
  • Another participant expresses confusion about the flow of integration and emphasizes the importance of simplicity in mathematical methods.
  • Several participants discuss the use of partial fractions in their approaches, with one noting a mistake in the integration process and suggesting corrections.
  • There are multiple proposed methods for integrating csc(x), leading to different expressions and results, with some participants questioning the validity of each other's approaches.
Participants do not reach a consensus on the best method for integrating csc(x). Multiple competing views and approaches are presented, with some participants correcting or refining each other's claims without establishing a definitive solution.
Some participants note the importance of back substitution and the inclusion of absolute value signs in their final answers. There are also references to potential complications in the integration process, indicating that not all steps are straightforward or resolved.
This discussion may be useful for students and individuals interested in calculus, particularly those looking for various techniques to solve integrals involving trigonometric functions.
PrudensOptimus
How do you find ∫ cscx dx?
Look it up in an integral table? {ln(tan(x/2))}
By seeing the trick used to find ∫ sec x dx and applying it to this problem.
(Your textbook almost certainly shows how to compute the integral of sec x, and if it doesn't, look up the answer in an integral table and work backwards to discover the trick)
∫ csc x dx = ∫ csc x * (csc x + cot x)/(csc x + cot x) dx
=∫ ((csc x)^2 + csc x cot x)/(csc x + cot x) dx
=-ln | csc x + cot x | + constant
hope it answers your question...
Now, that's just scary! :smile:
Here's how I would do it: csc(x)= 1/sin(x) so this is the same as ∫ dx/sin(x)- an odd power of x. Back in calculus, I learned that when you have an odd power of either sin(x) or cos(x), you can use one of them with dx and use sin2+ cos2= 1 for the rest: here sin(x) is in the denominator so I would write it as
∫sin(x)dx/sin2= ∫ sin(x)dx/(1- cos2(x)).
Now let u= cos(x) so du= sin(x)dx and the integeral becomes
∫ du/(1-u3). The denominator factors as (1-u)(1+ u) so- partial fractions. 1/(1-u2)= (1/2)/(1-u)+ (1/2)/(1+u).
The integral is now (1/2)∫du/(1-u)+ (1/2)∫du/(1+u)= -(1/2)ln|1-u|+ (1/2)ln|1+u|+C= (1/2)ln(|1+u|/|1-u|)+ C= (1/2)ln((1+sin(x))/(x-sin(x)))+ C= ln(√((1+sin(x))/(1-sin(x)))+ C
Hmmm, maybe Reihhard-t's solution isn't so scary after all!
I do not see the flow of your intergration.
but the most important ,when you do math,you must try the most simple,short, and clear...and get the best result.
what I did actually just multiply with 1 which is ∫(csc x + cot x)/(csc x + cot x) ...and then just carry two more steps,and done...
that's math all about
OK how about treating ∫ csc x dx as ∫ 1/sinx dx?
Here's what I had to far, I had 2 approaches
∫ 1/sinx dx = ∫ (1/sinx)*cosx/cosx dx
= ∫ (1/u)(1/cosx) du = ∫1/sqrt(u^2 - u^4) du.
I don't know how to continue from there, or is it even continuable at all?
2nd approach:
∫(1/sinx) dx = ∫sinx/sin^2x dx = ∫sinx/(1-cos^2x) dx
assuming u = cos x, du = -sinx
= ∫ 1/(u^2-1) du
Then I stop there... don't know how to continue. Or is it continuable??
You can use partial fractions to continue that, once you learn them.
HallsofIvy lost a negative u= cos(x) so du= -sin(x)dx
Can you teach me? Or someone please teach me?
actually all equation can be integrated,but for you case optimus,your further integration will be very complicated,and frankly speaking ,I don't know how to integrate more,to get exactly like my previous answer.
so I recommend you to implement my previos method.that one is actually a math trick.it is fast and incisive
OK here's what i got after trying partial fractions.
Integral of
1/sinx = sinx/(1-cos^2x) = 1/(u^2-1) du = 2/(u-1) - 2/(u+1)
So the integral is 2*(ln(u-1) - ln(u+1)) + C
Is that correct?
I think those twos should be one-halves.
Also, don't forget your absolute value signs!
And, finally, you need to back substitute to change the 'u's back into 'x's.
yeah.you've come with great idea optimus,just slight careless like what is mention by hurkvl.It is both(1/2) instead of 2,and ending it up with variable x together with modulus sign.
it becomes (1/2)ln |(cos x - 1)/(cos x + 1)|
