Algebra Confusion: Proving (A+C)*(A'+B)*(B+C) = B*C
  • Thread starter Thread starter zenity
    Algebra Confusion
The discussion revolves around proving the Boolean algebra expression (A+C)*(A'+B)*(B+C) = B*C. Participants express confusion regarding the steps taken and the underlying principles of Boolean algebra, particularly in relation to the implications of certain variable values.
  • Participants explore the expansion of the expression and question the validity of their steps. They discuss the implications of the conditions A*B = 0 and A+B = 1, and how these relate to the expression (A'+B). There is a focus on understanding how (A'+B) can be simplified to B under certain conditions.
Some participants have provided explanations regarding the simplification of (A'+B) to B, while others express uncertainty about the reasoning behind this step. The discussion is ongoing, with various interpretations and clarifications being explored.
Participants are working within the constraints of Boolean algebra rules and are attempting to reconcile their understanding with the formal definitions and properties of the variables involved.
zenity
Hi there,
I've never done this type of Algebra... and it's a bit confusing. I've completed this question, but I don't know if I took the right steps...
*=AND, +=OR, '=NOT
If A*B = 0, A+B=1
Prove: (A+C)*(A'+B)*(B+C) = B*C
I expanded it a bit and applied some of the rules. Can someone explain it step by step? I got the answer but I'm a bit confused at how I got the answer.
Thanks!
(A+C)*(A'+B)*(B+C)
= (A+C)*(B+C)*(A'+B) (commutation)
= ((A*B)+C)*(A'+B) (distribution)
= (0+C)*(A'+B) (substitution A*B = 0)
= C*(A'+B)
Now I don't know what "rules" you know or how formal you have to be, but you should be able to see that (A'+B) = B given A+B = 1. Clearly, if A'+B = 0, then B = 0. If A'+B = 1, we want B to also necessarily be 1. But suppose it's not, so suppose A'+B=1 but B=0. Then A' = 1, which means A=0. So both A and B would be 0, but we're given A+B = 1, which is a contradiction, so B does indeed have to be 1 if (A'+B) is 1.
Mhm.. I understood all the steps until the last one...this is what I think...
Since AB = 0 and A+B=1
That leaves us with two choices for A or B. A can either be 0 or 1, and B must be the exact compliment.
Now we're stuck with C(A'+B). *Here's where I'm a bit confused*
If A is 0, B will be 1, then A' + B = 1
If A is 1, B will be 0, then A' + B = 0
From which of these two can we say C*(A'+B) = B*C?
in otherwords... how does (A'+B) = B?
Well I've already told you how (A' + B) = B. However, if you didn't follow the explanation, then consider what you said yourself:
So B = A', right? So (A' + B) = B + B = B (Idempotence).
Ah... I think I understand what I just said. A'=B.. then you'd just have to sub it in.
Man, boolean algebra is mighty weird! I just started a week ago, still getting the hang of it. Thanks for your help!
how about a proof of A'=B
given A*B=0
(or with A')
A'+A*B=A'
(and with B)
A'*B + A*B*B=A'*B
=> (A'+A)*B=A'*B
=> B=A'*B (1)
given A+B=1
(and with A') => A'*A + A'*B = A'
=> A'*B = A'
(substitute from (1) ) => B=A'
