Decimal to binary, Decimal to Octal confusion
  • Thread starter Thread starter mr_coffee
    Binary Confusion
The discussion revolves around the methods for converting decimal numbers to binary and octal, particularly focusing on how to handle decimal fractions in these conversions. Participants explore various techniques and share their experiences in a digital design context.
  • One participant describes the initial method of converting whole numbers to binary and octal through division by 2 and 8, respectively, but expresses confusion about handling decimal fractions.
  • Another participant suggests separating the whole number and fractional parts for conversion, explaining the positional values for binary and octal.
  • There is a discussion about whether the dividing method is the only way to find values after the decimal point, with some participants proposing an alternative method involving multiplication by the base.
  • A participant proposes that instead of dividing, one can multiply the decimal fraction by 2 for binary or 8 for octal to find the corresponding values, which is met with acknowledgment from others.
  • One participant reflects on their misunderstanding of the relationship between division and multiplication in this context, indicating a learning moment.
  • A later post shares external resources for verifying conversion methods, suggesting that there are tools available for assistance.
Participants do not reach a consensus on the preferred method for converting decimal fractions to binary and octal, as multiple approaches are discussed and some participants express differing opinions on efficiency and clarity.
Some participants express uncertainty about the best method for converting decimal fractions, and there are unresolved questions about the efficiency of different techniques. The discussion reflects varying levels of familiarity with the concepts involved.
This discussion may be useful for students in digital design or related fields who are learning about number base conversions, particularly those struggling with decimal fractions in binary and octal systems.
mr_coffee
Hello everyone, I realize this is really basic stuff and mainly pointless considering calculators can do it for you but I'm still wondering on why this isn't working out right. I'm in a digital design class and he showed us a method for converting decimal to binary and it seemed easy and seemed to work great but he would use numbers such as: 25 and nothing that had a decimal point. Well the number is 369.3125 decimal. To convert to binary it worked fine for the whole number 369 by just divding by the desired base, so since i wanted binary, i would divide by 2 and the remainder of each would be the number in binary. Also if I wanted to convert decimal to octal, i could just keep on divding by 8, and so on. But as you can see I can't figure it out how you figure out the .3125 of the number by using the divding method? Also I'm having troubles converting it to octal using the dividing method. Here is my work in the picture. Any help would be great!
http://img139.imageshack.us/img139/7369/fff7vh.jpg
I'll give you a couple of hints. First, convert that to the left and that to the right separately. Second, where the left values (starting at the point) of binary numbers represent values of 1(ie 2^0), 2, 4, 8,...etc., those to the right represent values of 1/2 (ie, 2^-1), 1/4, 1/8,...etc.
KM
Same consideration for Octal, except the values to the left (starting at the point), are n*8, n*64, n*512,...etc., those to the right are n*1/8, n*1/64...etc. Operate on them accordingly.
KM
Thanks for the reply, well I know how to convert using that method, but I think it takes longer to do, is that the only way you can find the numbers after the decimal point? You can't use the dividing by power rule?
Sure you can. I thought what I told you would give you the answer. Hint: instead of repetitively dividing by two or eight, you divide repetitively by ?? or ??. (and what should that imply?)
KM
ohhh, instead of dividing by 2 or 8, it would be by 2^-1 then 2^-2? or 8^-1, etc>?
Yes, and what are those values, and what does the use of those values imply? You can check it on your example, because it is a very simple case.
KM
actually, I found a much easier way, you don't divide by anything, if you want to convert a decimal base 10, to a binary, just multiply by 2, and keep doing it, if u want octal, multiply by 8, its simple. THanks for the help though.
What do you think I was trying to hint to you. Dividing by 1/2 is the same as multiplying by 2. The same with 1/8 and 8, or any other base. Then whatever carries each time to the "left" of the point is the value you use.
KM
oh hah, sorry my bad, i forgot about the whole 1/.5 = 2. And I'm in calc III, sad. hah
I know this is an old post, but for some of you still reading this, you can use this http://www.stringfunction.com/decimal-binary.html" to make sure you are converting the right way.
Also, check this article on http://www.stringfunction.com/blog/convert-binary-and-decimal-values/"
Hope this help
David
9K
11K
10K
18K
